Parent topic: Enterprise Back Office Components and Services
install_ version.exe
to the Aggregation and Analysis server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
Table 9-2 Aggregation and Adjustment Service Login
Field | Description |
Core database login and Core database password |
Enter the core database login credentials. |
RTA database login and RTA database password |
Enter the RTA database login credentials. |
Portal database login and Portal database password |
Enter the Enterprise Back Office database login credentials. |
Location Activity database login and Location Activity database password |
Enter the location activity database login credentials. |
Name for Analysis/Aggregation Instance |
Enter a unique name for this instance of the analysis/aggregation service. The service inserts the name into the database to denote which service processed a job. |
Connection Cache Type |
Select a connection cache type from the drop-down list. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\
folder during installation, and to the installation path after completing installation.Parent topic: Installing the Aggregation and Adjustment Service
to the Reporting and Analytics application server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
C:\temp\
folder during installation, and to the installation path after completing installation.Related Topics
