To prevent conflicts due to server dependencies when starting or shutting down Reporting and Analytics, use the following diagram as a guideline for the order you should follow. For environments with server clusters, make sure to start the primary servers first, and to shut down the primary servers last.
Figure 11-1 Shutdown and Startup Order for Reporting and Analytics Servers
Parent topic: Administration and Maintenance
