Parent topic: Post-Installation Configuration
Follow the instructions to create and set up a location using Remote Transfer Agent. Make sure to set up a Master Group structure before creating the location.
You can import, view, and toggle the status of job scripts for Remote Transfer Agent.
You can configure jobs to run one or more scripts to a posting class.
You can create and maintain a list of jobs for each organization in the Remote Transfer Agent.
