Problem
Users do not see embedded charts in core reports.
Cause
Oracle Business Intelligence Publisher may have incorrect login configurations.
Resolution
Navigate to Fusion_Middleware_path\user_projects\domains\bifoundation_domain\config\bipublisher\ and open xmlp-server-config.xml in a text editor.
Find and replace the file path resource and config element as described in the following table:
Table 13-2 XML Change for Embedded Charts
| Find and Replace | With This |
<resource> <saw path=”/”><connection><version>v7</version> <sessionTimeOut>90</sessionTimeOut></connection> <init><source>middleware_installation_path/ user_projects/domains/bi_foundation_domain/ config/bipublisher/repository</source> </init></saw></resource> </resource> <config> <file path="${xdo.server.config.dir}/repository"/> </config> </xmlpConfig> |
<resource> <file path="${xdo.server.config.dir}/repository"/> </resource> <config> <file path="${xdo.server.config.dir}/repository"/> </config> </xmlpConfig> |
Restart the beasvc bifoundation_domain_bi_server1 service.
If the problem persists, the Oracle Business Intelligence Publisher documentation contains more troubleshooting information and instructions.
Parent topic: Troubleshooting
