Problem
When attempting to access Analysis Reports or a dashboard in Reporting and Analytics, the web browser returns the HTTP error 500 – Internal Server Error.
Cause
The HTTP error 500 – Internal Server Error is a generic server status code that signifies a problem with the web server.
Resolution
root\temp\MM_Log.log
INSTALLATION_DIR\Oracle\Middleware\user_projects\domains\bifoundation_domain\servers\server_name\logs
One possible cause for the error message is a server outage. For example, if beasvc bifoundation_domain_bi_serverX is not online, all operations related to Analysis Reports and dashboards return 500 – Internal Server Error. Check the Oracle WebLogic Administration Console for the status of servers, and start or restart any servers that are not active.
Parent topic: Troubleshooting
