Verify that the port specified for Oracle WebLogic Node Manager, which is by default 9556, is open and not used.
Verify that the required Java version is installed on the server. The Oracle MICROS Enterprise Back Office Release Notes lists environment requirements for the release.
Review the root\temp\MM_Log.log log file and refer to the Oracle WebLogic help.
Obiee Install
Obiee Patch
Verify that the file structure for the installation files matches the file structure in the downloaded installation archive.
Review the root\Program Files\Oracle\Inventory\logs log file and refer to the Oracle Business Intelligence Enterprise Edition help.
Review the following log files:
install directory\Oracle\Middleware\wlserver_version\common\nodemanager
If the Microsoft Windows service failed, check the Microsoft Windows system log using the Event Viewer.
Refer to the Oracle WebLogic Node Manager help.
In a web browser, navigate to http://WebLogic_AdminServer_Hostname:port/console where the default port is 7001.
If you cannot access the WebLogic console:
Verify that the port specified for the WebLogic AdminServer during installation is open and not used.
Review the root\temp\MM_Log.log log file.
If there is an issue regarding the AdminServer, review the logs in INSTALLATION_DIR\Oracle\Middleware\user_projects\domains\bifoundation_domain\servers\AdminServer\logs
Storing Configuration
Getting BI Server Name
App Cluster Creation
Remote Managed Server Creation
Node Manager Enrollment
JMS Creation (Add Modules, Add User, Add Policy)
JMS Server Creation
Enable Validate Basic Auth Credentials
Enable SSL (Portal, Obiee)
SAML EM Changes
Session Timeout
If you can access the WebLogic console, verify that the AdminServer(admin) server is running. Use the console to manually start the AdminServer if it is not running.
OBI server could not connect to Enterprise Back Office database server.
OBI server could not assign ports because they were closed or being used.
OBI server is using a dynamic IP address instead of a static IP address.
Java Development Kit installed in a folder containing spaces.
In cluster environments, non-primary server could not connect to the primary OBIEE server.
In cluster environments, the OBIEE managed server (bi_server) or OBIEE services are not running correctly on the primary OBIEE server.
Review the root\Program Files\Oracle\Inventory\logs log file.
If the log contains errors regarding the AdminServer, review the logs in INSTALLATION_DIR\Oracle\Middleware\user_projects\domains\bifoundation_domain\servers\AdminServer\logs
If the log contains errors regarding the bi_server, review the logs in INSTALLATION_DIR\Oracle\Middleware\user_projects\domains\bifoundation_domain\servers\bi_server\logs
Installation Stops Progressing at OBIEE Configuration contains information and instructions for cases where the installation stops progressing but does not add an error to the log files.
BI Cluster Configuration
SAML Enable SSO
SAML Primary Obiee
One or more of the following failed or is not running:
If you can access the WebLogic console, verify that the AdminServer(admin) server and the bi_servernumber is running. Use the console to manually start the AdminServer and the bi_server if they are not running.
If the log contains errors regarding the Oracle Process Manager, review the logs in INSTALLATION_DIR\Oracle\Middleware\instances\INSTANCE_NAME\diagnostics\logs , where INSTANCE_NAME can be ORCLRNA or HOSTNAME_ORCLRNA.
Refer to the Oracle WebLogic or the Oracle Business Intelligence Enterprise Edition help.
Oracle WebLogic AdminServer failed or is not running.
Managed Server failed or is not running.
The port specified for Oracle WebLogic AdminServer may not be open.
The port specified for Managed Servers may not be open.
Verify that the port specified for Managed Servers (bi_server and AppServer) are open and not used.
BIPChart DS creation
CoreDB DS creation
UserGroup DS creation
CoreDS creation
CEDS creation
Connection to database server failed.
Authentication for database user failed.
UserGroup data source created, but unable to connect to the database.
This error message occurs in cluster installations, and the component name identifies whether the error occurred on the primary OBI server or the non-primary OBI server.
Verify that the port specified for Managed Servers (bi_server) is open and not used.
If the log contains errors regarding the AppServer, review the logs in INSTALLATION_DIR\Oracle\Middleware\user_projects\domain\servers\APPSERVER_NAME\logs , where APPSERVER_NAME is appServ1 or HOSTNAME_appServ1.
Start OPMN Service
Stop OPMN Service
Refresh GUID
Global Cache
Setup mail in OBIEE EM
RPD Deployment
WebCatalog Deployment
Refer to the Oracle WebLogic or the Oracle Process Manager help.
If problems occur after attempting to remove or redeploy the application:
In the WebLogic console, verify that the AnalyticsRes, ObieeWebService, and LogoutApp web applications are Active in the Deployments list.
Review the logs in INSTALLATION_DIR\Oracle\Middleware\user_projects\domains\bifoundation_domain\servers\SERVER_NAME\logs to verify the deployment status of Reporting and Analytics.
Review the logs in INSTALLATION_DIR\Oracle\Middleware\user_projects\domains\bifoundation_domain\servers\bi_server\logs to verify the deployment status of the web applications.
Server Failed to Remove the Staged Files contains instructions for identifying and resolving the staged files issue.
