Make sure version number in the following databases is lower than the version to which you are upgrading, and delete equal or higher version numbers. For example, if you are upgrading to version 9.0, delete all versionnum entries that are equal to or greater than 9.0.
AGGREGATE_DB.AGG_VERSION_DB
BIREPOS.BIREPOS_VERSION_DB
CEDB.CE_VERSION_DB
COREDB.CORE_VERSION_DB
LOCATION_ACTIVITY_DB.VERSION_DB
PORTALDB.PORTAL_VERSION_DB
QUARTZ.QUARTZ_VERSION_DB
RTA.RTA_VERSION_DB
Parent topic: Troubleshooting
