Parent topic: Enterprise Back Office on Two Servers
/OBIEE/
/OBIEEPatch/
/Weblogic/
Install_version.exe
Install_version.exe to launch the installation wizard.Table 3-1 Oracle WebLogic Application Server Information
| Field | Description |
WebLogic User Name and WebLogic Password |
Create the login credentials for an administrator account on the WebLogic application server. The password must be eight to 20 characters, must not contain special characters, and must include at least one number. |
Local JVM Path |
Verify the folder path to the local Java Development Kit installation. This install path must not contain spaces. |
WebLogic Admin Server Host Name and WebLogic Admin Server Port |
Enter the hostname and port of the Oracle Business Intelligence server, typically 7001. |
BI Server Port |
Enter the port used by Oracle Business Intelligence, typically 9704. |
Node Manager port |
Enter the port used by the Node Manager, typically 9556. |
Table 3-2 Oracle Business Intelligence Enterprise Edition Database Information
RCU Database Location |
Enter the hostname of the Enterprise Back Office database containing the RCU installation. |
SQL Server or Oracle |
Select the database type. |
Port and Database Service Name |
Enter the port used by the database, and any additional connection parameters as necessary. |
BIPLATFORM Schema Password |
Enter the schema password you created for the RCU during database installation. |
MDS Schema Password |
Make sure the filepath includes the following components: folder_path/file_name.extension
Table 3-3 Database Information
| Oracle Database | Microsoft SQL Server |
Table 3-4 Repository Database Information
Table 3-5 Aggregation Database Information
Table 3-6 Online Analytical Processing Database Connection
OLAP Login and OLAP Password |
Enter the login credentials for the OLAP database. |
OLAP Server name or IP |
Enter the hostname of the OLAP database. |
OLAP DatabasePort |
Enter the OLAP database server port. |
OLAP DB SID |
Enter the SID for the OLAP database. |
The Mail Server is typically installed on the Reporting and Analytics application server.
Table 3-7 Portal/InfoDelivery Font Settings
Enable User Font |
Select whether to allow using a custom font when rendering PDFs. You can then enter the path to the font, or click Choose to navigate to the font. |
Limit detail query days |
Enter a date limit for executing audit/analysis detail queries. The Organization configuration can override this setting. |
Limit summary query days |
Enter a date limit for executing audit/analysis summary queries. The Organization configuration can override this setting. |
New Line Style for infoDelivery CSV format |
Select whether to use Windows, Unicode, or HTML line styling when formatting Report Mail items in CSV. |
Load reports by market segment |
Select whether to load reports dynamically by appending the organization or role market segment to the template name. |
http://Gift and Loyalty URL:80/offers/Table 3-8 Reporting and Analytics Configurations
Names of all Portal Application Servers |
Enter the hostnames of all Reporting and Analytics web application servers in a comma-separated list. |
Administrator e-mail address |
Enter the email address, without the domain, of the administrator account. |
What email user will the Portal use to send mail? |
Enter the email address, without the domain, that the Portal uses to send mail. |
What is the password for the email user? |
Enter the password for the portal email user. |
Use HTTPS protocol for portal? |
Select whether the web application uses the HTTPS protocol. This option requires a Secure Socket Layer (SSL) connection and should typically only be selected when the installation environment has an SSL accelerator. |
Password for Messaging Queue |
Enter the login credentials for the messaging queue. This field does not show when performing an upgrade. |
Username and Password for utility user |
Enter the login credentials for the UTIL account created during database installation. |
Username and Password for CE user |
Enter the login credentials for the CEDB account created during database installation. |
New Line Style for Portal CSV display |
Select whether to use Windows, Unicode, or HTML line styling when using the CSV export while viewing a report. |
Table 3-9 Report Mail Font Configurations
Enable User Font |
Select whether to allow using custom fonts when rendering PDFs. |
Path to user font |
Enter the path to a font, or click Choose and navigate to a font, to set the font used when rendering PDFs. |
New Line Style for InfoDelivery CSV format |
Table 3-10 Master Server Configurations
RTA database login and RTA database password |
Enter the RTA database login credentials for inserting and updating the |
COREDB login and COREDB password |
Enter the COREDB login credentials for file transport. The account must have the same level of permissions on the Core database/schema. |
Email account name for the Errors Administrator and Email account password |
Enter the e-mail account credentials for the Error Administrator. |
Merak 8.5 or higher |
Select whether Merak 8.5 or higher is installed on the environment. |
Where is the Merak installation located? |
If Merak is installed on the environment, enter the installation path. |
Server1 account password |
Enter the password for the server1 login account. |
Cache type for the Master Service |
Select the Master Service cache type from the drop-down list. |
Table 3-11 Posting Server Configurations
How many posting threads should run on the server simultaneously? |
Enter the number of simultaneous posting threads. Entering a number greater than eight can lead to performance degradation. |
How many days of psLogs should be saved? |
Enter the amount of days that the posting server preserves the Result sets and the entries in the |
What directory should hold psLogs? |
Enter the path to the folder where the posting server saves the logs in .zip format. |
Move History by location rather than full server? |
Select or deselect whether to move history by location rather than moving history by server. If you deselect this option, the admin server stops posting for the duration of the move. |
Limit move history day range |
Select or deselect whether to limit moving history by date. You should typically only use this option when you partition databases by date. |
What name would you like to use for Temporary Menu Items? |
Enter the name the posting server uses for temporary menu items. |
What database user should posting use? |
Enter the database account name for posting. |
What is the password for this user? |
Enter the database account password for posting. |
Run alignment with definitions posting? |
Select or deselect whether to run alignment while posting definitions. Select this option if the environment contains an aggregation engine. |
Table 3-12 Alert Engine Configurations
Push alert service username and Push alert service password |
Enter the login credentials for the push alert service. |
Number of alert threads |
Enter the number of alert threads. |
Portal DB User and Portal DB Password |
Enter the Enterprise Back Office database login credentials. |
Core DB User and Core DB Password |
Enter the core database login credentials. |
Location Activity DB User and Location Activity DB Password |
Enter the location activity database login credentials. |
RTA DB User and RTA DB Password |
Enter the RTA database login credentials. |
CE DB User and CE DB Password |
Enter the CE database login credentials. |
Table 3-13 Admin Server Configurations
Trailer to send in alerts from Admin Server |
Enter trailer text in the four fields provided. |
Email account to send alerts from |
Enter the email name, without the domain, that the Admin Server uses to send alerts. |
Number of hours before a location is considered out of contact |
Enter the maximum number of hours before the Admin Server flags an unresponsive location. |
Email addresses to send long alert messages to |
Enter the email name, without the domain, to which the Admin Server sends long alert messages. You can separate multiple addresses with a comma. |
Email addresses to send short alert messages to |
Enter the email name, without the domain, to which the Admin Server sends short alert messages. You can separate multiple addresses with a comma. |
Email addresses to send copies of org alerts to |
Enter the email name, without the domain, to which the Admin Server sends a copy of all alerts. |
Folder containing custom packages for Admin Server |
Enter a folder path containing custom packages. |
Table 3-14 Aggregation and Adjustment Service Login
Core database login and Core database password |
Portal database login and Portal database password |
Location Activity database login and Location Activity database password |
Name for Analysis/Aggregation Instance |
Enter a unique name for this instance of the analysis/aggregation service. The service inserts the name into the database to denote which service processed a job. |
Connection Cache Type |
Select a connection cache type from the drop-down list. |
Table 3-15 Weather Configurations
What is the database login for the Weather Service? |
Enter the username for the database login, typically MSSQL. |
What is the database password for the Weather Service? |
Enter the password for the database login. |
How many days of weather should be stored in the database? |
Enter the number of days of weather information that should be stored and retained in the database. Enter 0 to disable database storage. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
WebLogic Domain folder.
oracle.bi.enterprise folder, select mail.server, and then click Delete.
Parent topic: Installing the Oracle Business Intelligence Server
root\temp\MM_Log.log
root\temp\MMInstaller.log
root\myMicros\Uninstall_myMicros\myMicros_Install_datetime.log
root\Program Files\Oracle\Inventory\logs\ for error messages.OBI server hostname:7001/console and log in using the WebLogic administrator account credentials created during the installation.beascv bifoundation_domain_AdminServer
beasvc bifoundation_domain_bi_server1
Oracle Process Manager (ORCLRNA)
Oracle WebLogic NodeManager(path to Oracle Middleware wlserver installation)
root\myMicros\Oracle\Middleware\instances\ORCLRNA\bin\Figure 3-2 Two-Server OBIEE opmnctl Status
Related Topics
