DBInstall.exe from the installation file archive to the Gift and Loyalty database server. Do not extract the file to a folder structure that contains spaces. You can extract the file to another server and run the installation wizard using a network connection.DBInstall.exe to launch the database installation wizard.If you are installing a new shell database, install a clean Microsoft SQL Server with no Gift and Loyalty objects.
C:\Temp\DBInstaller.log to verify that the installation finished without any errors.Related Topics
Parent topic: Gift and Loyalty
