Parent topic: Gift and Loyalty
Before installing the Gift and Loyalty application:
Verify that your server meets the system requirements. The Application Server Compatibility and Requirements section in the Oracle MICROS Enterprise Back Office Release Notes contains compatibility and requirement information.
Install the required Java Development Kit version in a folder path that does not contain spaces. For example, do not install Java in the default Program Files path.
Verify that the 7001, 9704, and 9556 ports are not being used.
Verify that the Gift and Loyalty server can connect to the Gift and Loyalty database server.
Obtain a Secure Socket Layer (SSL) certificate for the Gift and Loyalty application server.
Disable tunnel adapters. Disabling Tunnel Adapters contains information and instructions for checking for and disabling the adapter.
Parent topic: Installing the Gift and Loyalty Application Server
Follow the instructions to configure Gift and Loyalty settings for all organizations in Enterprise Back Office:
By default, Gift and Loyalty uses the same listening ports as Reporting and Analytics. If you installed Gift and Loyalty on the Reporting and Analytics application sever, change the listening ports to unused ports using the following steps:
Related Topics
