Verify that your installation environment meets the prerequisites.
Install the Inventory Management applications.
Follow the instructions in the Inventory Management Security Guide to set up the encryption keys and configurations.
Prepare the Inventory Management database servers.
Install or update the Inventory Management databases.
Configure the connection to Reporting and Analytics.
