Parent topic: Inventory Management
Oracle MICROS recommends setting the following Oracle Database configurations when creating the database instance and before running the Inventory Management product installer. While some configurations can be changed after the installation, preparing the database instance prior to schema installation can prevent unexpected errors and problems.
Oracle Database Configuration for Inventory Management Database
| Parameter | Recommended Value | |
Instance Name |
<CustomerName><Environment ID><EnvironmentPurpose P/S/T>INV For example, for customer ABC, environment ID 1, and environment purpose P for production: ABC01PINV |
db_block_size |
8192 |
open_cursors |
1000 |
db_recovery_file_dest_size |
Set as the amount of storage allocated to FRA and DATA. |
job_queue_processes |
64 |
aq_tm_processes |
1 |
session_cached_cursors |
100 |
optimizer_mode |
first_rows_10 |
optimizer_index_caching |
20 |
optimizer_index_cost_adj |
20 |
cusrsor_sharing |
exact |
processes |
1024 |
sga_max_size |
Set as 50% of database RAM, to be tuned by the DBA during the life of the environment. |
sga_target |
Set as the same value as sga_max_size. |
pga_target |
Set as 25% of sga_target. |
Oracle Database Tablespaces for Inventory Management Database
USERS
TEMP
Parent topic: Installing Inventory Management on Oracle Database
Follow these instructions to set up the Oracle Database shell before installing Inventory Management.
Related Topics
