install_ version.exe to the InfoDelivery server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
| Oracle Database | Microsoft SQL Server |
Table 9-5 Report Mail Font Configurations
| Field | Description |
Enable User Font |
Select whether to allow using custom fonts when rendering PDFs. |
Path to user font |
Enter the path to a font, or click Choose and navigate to a font, to set the font used when rendering PDFs. |
Limit detail query days |
Enter a date limit for executing audit/analysis detail queries. The Organization configuration can override this setting. |
Limit summary query days |
Enter a date limit for executing audit/analysis summary queries. The Organization configuration can override this setting. |
New Line Style for InfoDelivery CSV format |
Select whether to use Windows, Unicode, or HTML line styling when formatting Report Mail items in CSV. |
Load reports by market segment |
Select whether to load reports dynamically by appending the organization or role market segment to the template name. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\ folder during installation, and to the installation path after completing installation.Related Topics
Parent topic: Enterprise Back Office Components and Services
