install_ version.exe to the Remote Transfer Agent Posting server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
| Oracle Database | Microsoft SQL Server |
Table 9-4 Posting Server Configurations
| Field | Description |
How many posting threads should run on the server simultaneously? |
Enter the number of simultaneous posting threads. Entering a number greater than eight can lead to performance degradation. |
How many days of psLogs should be saved? |
Enter the amount of days that the posting server preserves the Result sets and the entries in the |
What directory should hold psLogs? |
Enter the path to the folder where the posting server saves the logs in .zip format. |
Move History by location rather than full server? |
Select or deselect whether to move history by location rather than moving history by server. If you deselect this option, the admin server stops posting for the duration of the move. |
Limit move history day range |
Select or deselect whether to limit moving history by date. You should typically only use this option when you partition databases by date. |
What name would you like to use for Temporary Menu Items? |
Enter the name the posting server uses for temporary menu items. |
What database user should posting use? |
Enter the database account name for posting. |
What is the password for this user? |
Enter the database account password for posting. |
Run alignment with definitions posting? |
Select or deselect whether to run alignment while posting definitions. Select this option if the environment contains an aggregation engine. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\ folder during installation, and to the installation path after completing installation.Related Topics
Parent topic: Enterprise Back Office Components and Services
