Parent topic: Enterprise Back Office Components and Services
install_ version.exe to the Remote Transfer Agent Master server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
| Oracle Database | Microsoft SQL Server |
Table 9-3 Master Server Configurations
| Field | Description |
RTA database login and RTA database password |
Enter the RTA database login credentials for inserting and updating the |
COREDB login and COREDB password |
Enter the COREDB login credentials for file transport. The account must have the same level of permissions on the Core database/schema. |
Email account name for the Errors Administrator and Email account password |
Enter the e-mail account credentials for the Error Administrator. |
Merak 8.5 or higher |
Select whether Merak 8.5 or higher is installed on the environment. |
Where is the Merak installation located? |
If Merak is installed on the environment, enter the installation path. |
Server1 account password |
Enter the password for the server1 login account. |
Cache type for the Master Service |
Select the Master Service cache type from the drop-down list. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\ folder during installation, and to the installation path after completing installation.Parent topic: Installing the Remote Transfer Agent Master Server
install_ version.exe to the Reporting and Analytics application server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
C:\temp\ folder during installation, and to the installation path after completing installation.Related Topics
