If you are upgrading Oracle MICROS Enterprise Back Office from 8.5.1.5 to 9.0 or later and you want to generate the subject area mapping report for Interactive Reports and Ad Hoc reports, you must use the Interactive and Ad Hoc Reports metadata extraction tool before uninstalling Reporting and Analytics. If you are using an early Enterprise Back Office version, you must upgrade to 8.5.1 and apply patch 5 before you can perform these steps.
Parent topic: Uninstallation
