Uninstalling Enterprise Back Office 8.5 or Earlier
If you are upgrading to Enterprise Back Office 9.0 or later and you want to generate metadata outputs of legacy reports, you must generate metadata for legacy reports before uninstalling Enterprise Back Office. You will not be able to recover the reports after you uninstall the earlier version of Enterprise Back Office.
On each server hosting an Enterprise Back Office component or service:
Navigate to the myMicros installation directory.
To create a backup of the configurations, copy the myMicros folder to a backup location.
You cannot restore the configurations from older versions. You can only use the backup as a configuration reference.
Make sure the current Microsoft Windows user has Change permissions for the myMicros folder.
Navigate to installation path\myMicros\Uninstall_myMicros\, and then double-click Change myMicros Installation.
Follow the instructions, and then click Next to uninstall the Enterprise Back Office components on the current server. You cannot stop or cancel the uninstallation process.
Delete the myMicros folder to remove all files that were not removed by the uninstallation wizard.
