Follow these instructions to set up a loyalty program that accumulates a loyalty points based on the subtotal of a check.
To issue points for each dollar spent, select Per check value, and then enter the number of points per dollar in Point Factor.
To issue points for each dollar spent on selected items, select Value of selected items, and then enter the number of points per dollar in Point Factor.
To issue points for each dollar spent in the entire transaction if one or more selected items is purchased, select Per check value if any selected, and then enter the number of points per dollar in Point Factor.
To issue a point by incremental amount on the check, select Per defined check value, and then enter the dollars per point in Per Defined Value.
Sync Menu Items
Sync Menu Item Masters
Sync Family Groups
Sync Family Group Masters
Sync Major Groups
Sync Major Group Masters
Parent topic: Loyalty Programs
