Parent topic: Enterprise Back Office Components and Services
install_ version.exe to the Admin Server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
Table 8-1 Admin Server Configurations
| Field | Description |
Trailer to send in alerts from Admin Server |
Enter trailer text in the four fields provided. |
Email account to send alerts from |
Enter the email name, without the domain, that the Admin Server uses to send alerts. |
Number of hours before a location is considered out of contact |
Enter the maximum number of hours before the Admin Server flags an unresponsive location. |
Email addresses to send long alert messages to |
Enter the email name, without the domain, to which the Admin Server sends long alert messages. You can separate multiple addresses with a comma. |
Email addresses to send short alert messages to |
Enter the email name, without the domain, to which the Admin Server sends short alert messages. You can separate multiple addresses with a comma. |
Email addresses to send copies of org alerts to |
Enter the email name, without the domain, to which the Admin Server sends a copy of all alerts. |
Folder containing custom packages for Admin Server |
Enter a folder path containing custom packages. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\ folder during installation, and to the installation path after completing installation.Parent topic: Installing the Admin Server
install_ version.exe to the Reporting and Analytics application server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
C:\temp\ folder during installation, and to the installation path after completing installation.Related Topics
