Problem
If you were using the installation wizard, you can verify this error message in root\temp\MM_Log.log
If you were using the Oracle WebLogic console, you can verify this error message in Oracle WebLogic installation path\Oracle\Middleware\user_projects\domains\WebLogic domain\servers\AdminServer\logs\
. The WebLogic domain is typically bifoundation_domain for Reporting and Analytics and icare_domain for Gift and Loyalty.
Deployment command type : deploy
Deployment State : failed
Deployment Message : weblogic.management.DeploymentException: [Deployer:ID]Server failed to remove the staged files.
Cause
The Oracle WebLogic installation could not remove a file from the Oracle WebLogic installation path\Oracle\Middleware\user_projects\domains\WebLogic domain\servers\application server domain\stage\
folder.
Resolution
Stop the application server.
Remove the \stage\
folder.
Start the application server, and then attempt installation again.
Parent topic: Troubleshooting
