When the installation wizard encounters a problem, it shows the message The following component did not install successfully followed by the name of the installation component that failed to install. The following table provides a reference of the components, possible reasons for the component to fail installing, and steps for troubleshooting the installation failure.
Table 12-1 Server Installation Errors
| The Following Component Did Not Install Successfully | Cause(s) | Corrective Action(s) | |
Verify that the port specified for Oracle WebLogic Node Manager, which is by default 9556, is open and not used. Verify that the required Java version is installed on the server. The Oracle MICROS Enterprise Back Office Release Notes lists environment requirements for the release. Review the |
Verify that the port specified for Oracle WebLogic Node Manager, which is by default 9556, is open and not used. Review the following log files:
Refer to the Oracle WebLogic Node Manager help. |
In a web browser, navigate to If you cannot access the WebLogic console:
In a web browser, navigate to If you can access the WebLogic console, verify that the AdminServer(admin) server is running. Use the console to manually start the AdminServer if it is not running. If you cannot access the WebLogic console:
If problems occur after attempting to remove or redeploy the application, review the logs in Server Failed to Remove the Staged Files contains instructions for identifying and resolving the staged files issue. |
Parent topic: Troubleshooting
