iCare_config_Options settings as follows:
The system evaluates the iCard.lockout.numTries and iCard.lockout.evaluationTimeInSecs values to determine if an IP address is blocked. It is possible for an IP address to be blocked even if an account is not locked.
Using the default values as an example, if 10 attempts are made from the same IP address within 5 seconds, the IP address is blocked for the duration defined in iCard.lockout.lockoutTimeInMins (default: 240).
The system evaluates the iCard.lockout.numTries to determine if the account is locked.
Using the default values as an example, if 10 consecutive unsuccessful login attempts are made to an account, the account is locked for the duration defined in iCard.lockout.lockoutTimeInMins (default: 240).
When you make changes to the icare_whitelisted_ips table and iCare_config_Options table, the changes do not take effect for approximately 15 minutes. Restart the Gift and Loyalty application server to immediately implement the changes.
Parent topic: Post-Installation Configuration
