For Oracle internal use during Oracle Cloud installations.
- Unzip
Installer.zip in <drive>:\IMSetup.
- Go to
<drive>:\IMSetup\Installer right-click WebAppInstaller.exe, and select Run as administrator.
- Select the web applications and services to install. You can change the web path, which will then update the local path if another location is preferred to the default.
- Select the destination application pool and then click Use this App Pool. To create an application pool, enter a name and then click Add Application Pool.
- After the installation is complete, review the summary for errors.
- Navigate to Internet Information Services (IIS) Manager, select Applications Pools. Verify that for the DefaultAppPool, v4.0 is set for the .NET CLR Version and that Managed pipeline mode = Integrated.
