<date>_HIM_DBMaintenance(64-bit)_9.1.x.x.x.zip in <drive:>\IMSetup\91Patchx. Use the appropriate 32-bit or 64-bit version for your system and for the Oracle Client.Program Files folder. Then, enter the Oracle instance name.sql.config in a text editor. Verify server names and add others if necessary. The values in bold are specific to your environment:
<servers> <server name=“<Oracle Server Instance>”><DbBrand value=“ORACLE”/> <ServiceName value=“<Oracle Server Instance>”/> </server> </servers>
FMLOGIN.INI and update and save:
DBLogin=<Oracle Server Instance>/<User(Organization Short Name)>/<user password>,<Organization Short Name>,myinvenMenu.iniFMLOGIN.INI.[BatchUpdate] MaxThreads=number of threads
Depending on your hardware configuration, enter a value between 10 and 30 for MaxThreads.
Click Settings and then select Daily Totals.
Click Database Update and then select Database Update to insert the tables, columns, and views. Verify that the update completes without errors.
Select Reorganization to add and remove database procedures and functions. Verify that the update completes without errors.
Parent topic: Install the Inventory Management Database
