You can enable other ports for HTTPS in Gift and Loyalty, such as 443:
- Log in to the Gift and Loyalty Oracle WebLogic console.
- In the Domain Structure, click iCare_Domain, click Environment, click Servers, and then in the table of servers, click icare_server.
- Click the Protocol tab, click the Channels tab, click Lock & Edit, and then click New.
- Fill out the Create a New Network Channel form:
- Enter a name, and then select https from the Protocol drop-down list.
- Enter 443 (or another open and unused port) in Listen Port and External Listen Port. Do not enter 7001 or 9443.
- Select Enabled and HTTP Enabled for This Protocol.
- If you installed a security for 9443 during the Gift and Loyalty installation, select Use Server’s SSL Identity from the Channel Identity drop-down list. Select Customize Identity to enter a new SSL certificate.
- Click Finish and activate the changes.
