install_ version.exe to the Weather server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
| Oracle Database | Microsoft SQL Server |
Table 8-7 Weather Configurations
| Field | Description |
What is the database login for the Weather Service? |
Enter the username for the database login, typically MSSQL. |
What is the database password for the Weather Service? |
Enter the password for the database login. |
How many days of weather should be stored in the database? |
Enter the number of days of weather information that should be stored and retained in the database. Enter 0 to disable database storage. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\ folder during installation, and to the installation path after completing installation.Related Topics
Parent topic: Enterprise Back Office Components and Services
