Media Profile Configuration
In the ACLI, you can set media profiles that are required for translating H.323 Slow Start to Fast Start. In the ACLI, you set the following:
name encoding name used in sdp rtpmap attribute media-type media type used in sdp m lines payload-type rtp payload type used in sdp m lines transport transport protocol used in sdp rtpmap attribute req-bandwidth amount of bandwidth in kilobits required frames-per-packet maximum number of frames per packet parameters list of <name=value> pairs separated by space average-rate-limit average rate limit of rtp flow
To configure a media profile:
