SIP Session Agent Options
The following table lists the SIP session agent options supported by the Oracle® Enterprise Session Border Controller.
| Option | Description |
| dropResponse | The Oracle® Enterprise Session Border Controllerdrops responses by specified status codes. The option value can contain one or more status codes separated by semicolons. Error ranges can also be entered. If any of the response codes matches then a response is not sent. If the dropResponse option is set in both the sip-interface and the session-agent elements, the session-agent setting takes precedence. |
| trans-timeouts=<value> | Defines the number of consecutive non-ping transaction timeouts that will cause a session agent to be out of service. When the session agent is configured, i.e. when the PING options are defined, the value is 10. If not defined, the default value is 5. A Value of 0 prevents the session agent from going out of service because of a non-ping transaction timeout. |
| via-origin=<parameter-name> | Causes a parameter to be included in the top Via header of requests sent to the session agent. The parameter indicates the source IP address of the corresponding request received by the
<parameter-name> defines the name of the parameter. If not specified, the default value origin is used. |
| refer-reinvite | Enables SIP REFER with Replaces. |
