SIP Realm Options
The following table lists the SIP session agent options supported by the Oracle® Enterprise Session Border Controller.
| Option | Description |
| number-normalization | Applies to the SIP To URI. (Currently the
Oracle® Enterprise Session Border Controller supports number normalization on From and To addresses for both inbound and outbound call legs.) Number normalization includes add, delete, and replace string functions that result in consistent number formats.
Number normalization occurs on ingress traffic, prior to the generation of accounting records or local policy lookups. (also applies for H.323 to SIP calls.) |
| refer-reinvite | Enables SIP REFER with Replaces. |
