This chapter provides information about the physical data model of Oracle Utilities Data Model.
This chapter includes the following sections:
The Physical Data Model of the Oracle Utilities Data Model is the physical manifestation of the logical data model into database tables and relationships (or foreign key constraints). Partitions, indexes, and Materialized Views have been added to aid performance.
Do not make changes to the schemas as such changes are not supported.
Oracle Utilities Data Model provides the following types of tables:
Reference tables contain information that is usually used as dimensions. They usually do not change often (or at all). Typically, Reference tables are PARTY, CUSTOMER, ADDRESS LOCATION, ACCOUNT, SUBSCRIPTION, and so on
Lookup tables in the foundation layer are added to save the definition of short codes used in other tables.
Base tables store information about any type of transactions (Invoices, Payments, Business Interactions, and so on). They are usually transformed into facts.
Derived Tables in the analytic layer are usually transition tables to STARs. They are also leveraged for the Mining models.
Aggregate Tables, or materialized views, are the STAR schema themselves at a higher level of aggregation. They may be related to the OLAP cubes.
Other table types, as show in Table 4-2.
For more information on Oracle Utilities Data Model table types, see "What is Oracle Utilities Data Model".
Table 4-1 shows the table name prefix conventions. When you examine the predefined physical model, keep in mind the naming conventions shown in Table 4-1 that use DW (Data Warehouse) prefixes to identify the types of tables and views.
Table 4-1 Table Name Prefix Conventions
| Prefix | Description |
DWA_ |
Aggregate table |
DWB_ |
Base transaction table |
DWD_ |
Derived table (Mining included) |
DWL_ |
Lookup table |
DWR_ |
Reference data table |
Table 4-2 Other Table Name Prefix Conventions
DM$ and DR$ |
Created when the mining models are trained. Used to store trained model and logs. |
CUBE |
Created when OLAP cubes are built. Used to store logs and results. |
Table 4-3 briefly describes the Reference tables in Oracle Utilities Data Model.
Table 4-3 Reference Tables
| Table Name | More Information |
DWR_AC_LN_SGMNT |
DWR_AC_LN_SGMNT_PHS |
DWR_ACCMLTR_LMT |
DWR_ACCMLTR_LMT_SET |
DWR_ACCMLTR_LMT_SET_ASGN |
DWR_ACCT |
DWR_ACCT_AGRMNT_RLTN |
DWR_ACCT_ASGN |
DWR_ACCT_BAL_GRP |
DWR_ACCT_BLLG_CYCL_HIST |
DWR_ACCT_BLLG_FREQNCY_HIST |
DWR_ACCT_BLLG_PRD_HIST |
DWR_ACCT_BSNS_INTRACN_RL |
DWR_ACCT_CYCL |
DWR_ACCT_PREF_INVC_DLVRY |
DWR_ACCT_PREF_PYMT_MTHD |
DWR_ACCT_PRFL |
DWR_ACCT_SGMNT |
DWR_ACCT_SGMNT_ASGN_HIST |
DWR_ACCT_SGMNT_MDL |
DWR_ACPT_TEST |
DWR_ACTV_POWR_LMT |
DWR_ADDR_LOC |
DWR_AGRMNT |
DWR_AGRMNT_DOC |
DWR_AGRMNT_ITEM |
DWR_AGRMNT_ITEM_PRCNG_STRUCT_ASGN |
DWR_AGRMNT_USG_PNT_ASGN |
DWR_AIR_CMPRSR |
DWR_ANLG_LMT |
DWR_ANLG_LMT_SET |
DWR_ANLG_LMT_SET_ASGN |
DWR_ANZSC_CLSFCTN |
DWR_APRNT_POWR_LMT |
DWR_ASST |
DWR_ASST_ACTVTY_REC_ASGN |
DWR_ASST_FNCTN |
DWR_ASST_INFO |
DWR_ASST_LOC |
DWR_ASST_MDL |
DWR_ASST_MDL_CTLG |
DWR_ASST_MDL_CTLG_ITEM |
DWR_ASST_ORG_RL |
DWR_ASST_ORG_RL_ASGN |
DWR_ASST_OWNR |
DWR_ASST_PSR_ASGN |
DWR_ASST_STAT |
DWR_ASST_USER |
DWR_BASE_VLTG |
DWR_BLLG_CYCL |
DWR_BLLG_FREQNCY |
DWR_BNK |
DWR_BNK_DRCT_DEBT_CHNL |
DWR_BRKR |
DWR_BSBR_SECTN |
DWR_BSBR_SECTN_INFO |
DWR_BSHNG |
DWR_BSNS_CASE |
DWR_BSNS_HLF_MO |
DWR_BSNS_HLF_YR |
DWR_BSNS_INTRACN_ASGN |
DWR_BSNS_INTRACN_LOC_ASGN |
DWR_BSNS_INTRACN_VRSN |
DWR_BSNS_MO |
DWR_BSNS_QTR |
DWR_BSNS_UNIT_JB_RL |
DWR_BSNS_WK |
DWR_BSNS_YR |
DWR_CAES_PLNT |
DWR_CALL_CNTR |
DWR_CALL_CNTR_AGNT |
DWR_CALL_CNTR_SRVC_CAPBLTY |
DWR_CGNRTN_PLNT |
DWR_CHNL |
DWR_CLMP |
DWR_CLNDR_HLF_MO |
DWR_CLNDR_HLF_YR |
DWR_CLNDR_MO |
DWR_CLNDR_QTR |
DWR_CLNDR_WK |
DWR_CLNDR_YR |
DWR_CLRNCE_ACTN |
DWR_CLRNCE_DOC |
DWR_CMBND_CYCL_PLNT |
DWR_CMPGN |
DWR_CMPGN_CHNL |
DWR_CMPGN_CHNL_ASGN |
DWR_CMPGN_CHTRSTC |
DWR_CMPGN_CHTRSTC_VAL |
DWR_CMPGN_DOC |
DWR_CMPGN_MGMT_HIST |
DWR_CMPGN_MSG |
DWR_CMPGN_MSG_DPCT |
DWR_CMPGN_RLTN |
DWR_CMPGN_TERM_VAL |
DWR_CMPST_SWTCH_INFO |
DWR_CMPTBL_UNIT |
DWR_CMPTBL_UNIT_PROC_ASGN |
DWR_CNCT_LST |
DWR_CNCTR |
DWR_CNDCTR |
DWR_CNDTNG_EQP_PRTCTN_EQP_ASGN |
DWR_CNFRM_LD |
DWR_CNFRM_LD_GRP |
DWR_CNFRM_LD_SCHL |
DWR_CNSMPTN_TIER |
DWR_CNSMPTN_TRF_INTRVL |
DWR_COLLCTN_AGNCY |
DWR_COMUNICTN_FNCTN |
DWR_COMUNICTN_LNK |
DWR_COMUNICTN_MEDIA |
DWR_COMUNICTN_MODULE |
DWR_CONCT_DSCNCT_FNCTN |
DWR_CONCTVT_ND |
DWR_CONCTVT_ND_CONTNR |
DWR_COST_CNTR |
DWR_CRDT_CTGRY |
DWR_CRDT_SCR_PRVDR |
DWR_CREW |
DWR_CREW_MBR |
DWR_CREW_TYP |
DWR_CREW_WRK_TASK_ASGN |
DWR_CRNCY_GEO_ENT_ASGN |
DWR_CRTCL_PK_PRD |
DWR_CRVE |
DWR_CURR_LMT |
DWR_CURR_RLY |
DWR_CURR_TRNSFRMR_INFO |
DWR_CUST |
DWR_CUST_ACCT_ASGN |
DWR_CUST_DOC |
DWR_CUST_FCNG_SRVC |
DWR_CUST_GRP_ASGN |
DWR_CUST_INDVL |
DWR_CUST_OCCSN |
DWR_CUST_ORDR_DOC |
DWR_CUST_ORG |
DWR_CUST_OUTG_NOTFCTN_ASGN |
DWR_CUST_RSTRCT_INFO |
DWR_CUST_RVN_BND_ASGN |
DWR_CUST_SCR |
DWR_CUST_SGMNT |
DWR_CUST_SGMNT_MDL |
DWR_CUST_SIC_ASGN |
DWR_CUST_SRC |
DWR_CUST_WRK_ASGN |
DWR_CUT |
DWR_CUT_ACTN |
DWR_DAY |
DWR_DC_CNDCTNG_EQPMNT |
DWR_DC_LN_SGMNT |
DWR_DEMAND_RESPN_PROG |
DWR_DEMAND_TRF_INTRVL |
DWR_DEMOG_ATRIB |
DWR_DEMOG_CHTRSTC |
DWR_DEMOG_GRP |
DWR_DOC_TYP_GRP_ASGN |
DWR_DR_PROG_AGRMNT_ASGN |
DWR_DR_PROG_END_DVC_GRP_ASGN |
DWR_DRVD_VAL |
DWR_DSCNCTR |
DWR_ELCTRCTY_SRVC |
DWR_EMP |
DWR_EMP_JB_RL_ASGN |
DWR_EMP_LANG_CAPBLTY |
DWR_EMP_RSTRCT_INFO |
DWR_EMP_SCHL |
DWR_END_DVC |
DWR_END_DVC_CAPBLTY |
DWR_END_DVC_CNTRL_TYP |
DWR_END_DVC_END_DVC_CTRL_ASGN |
DWR_END_DVC_END_DVC_GRP_ASGN |
DWR_END_DVC_EVT_DTL |
DWR_END_DVC_FNCTN |
DWR_END_DVC_GP_END_DVC_CTL_ASN |
DWR_END_DVC_GRP |
DWR_END_DVC_INFO |
DWR_ENRGY_AREA |
DWR_ENRGY_CONSMR |
DWR_ENRGY_CONSMR_PHS |
DWR_EQPMNT_CONTNR |
DWR_EXTRNL_CRDT_PRFL |
DWR_EXTRNL_CRDT_PRFL_ASGN |
DWR_EXTRNL_INFO_SRC |
DWR_FCT_DVC |
DWR_FEDR |
DWR_FEDR_SBSTN_ASGN |
DWR_FINCL_INFO |
DWR_FLT |
DWR_FLT_IND_INFO |
DWR_FREQNCY_CONVRTR |
DWR_FSCL_QTR |
DWR_FSCL_YR |
DWR_FUSE |
DWR_FXBLE_CHTRSTC |
DWR_GATE_INPUT_PIN |
DWR_GEN_UNIT_OP_COST_CRVE |
DWR_GEN_UNIT_OP_SCHL |
DWR_GEO_BLDG |
DWR_GEO_CITY |
DWR_GEO_CMPLX |
DWR_GEO_CNTRY |
DWR_GEO_CNTY |
DWR_GEO_DEMOG_ATRIB |
DWR_GEO_DEMOG_GRP |
DWR_GEO_DEMOG_VAL |
DWR_GEO_ENT |
DWR_GEO_ENT_ASGN |
DWR_GEO_ENT_HRCHY_LVL_ASGN |
DWR_GEO_HRCHY |
DWR_GEO_HRCHY_LVL |
DWR_GEO_HRCHY_LVL_ASGN |
DWR_GEO_LVL |
DWR_GEO_LVL_ATRIB |
DWR_GEO_LVL_ATRIB_VAL |
DWR_GEO_RGN |
DWR_GEO_SB_RGN |
DWR_GEO_STATE |
DWR_GEO_STREET |
DWR_GEO_WORLD |
DWR_GL_ACCT |
DWR_GL_ACCT_ASGN |
DWR_GL_ACCT_SGMNT |
DWR_GL_COST_CNTR_SGMNT |
DWR_GL_LDGR |
DWR_GL_LDGR_ACCT_ASGN |
DWR_GL_ORG_BSNS_UNIT_SGMNT |
DWR_GL_PRD |
DWR_GL_PROD_SPECFTN_SGMNT |
DWR_GL_PROJ_SGMNT |
DWR_GL_SBLDGR |
DWR_GL_SGMNT |
DWR_GNRC_ACTN |
DWR_GNRTNG_UNIT |
DWR_GNRTNG_UNIT_ROTTNG_MC_ASGN |
DWR_GRND_DSCNCTR |
DWR_GRND_SWTCH |
DWR_GRS_TO_NET_ACTV_POWR_CRVE |
DWR_HEAD_END_SYS |
DWR_HH |
DWR_HR |
DWR_HR_TIME_OF_USE_ASGN |
DWR_HYDRO_GNRTNG_UNIT |
DWR_INCDNT_WRK_ASGN |
DWR_INDVL_DEMOG_VAL |
DWR_INSTLMNT_AGRMNT |
DWR_INTRACN_CHNL |
DWR_INTRACN_NAVGTN_ITEM |
DWR_INVC_ADJ_QTA |
DWR_IRGLR_INTRVL_SCHL |
DWR_IRGLR_TIME_PNT |
DWR_JB |
DWR_JB_RL |
DWR_JMPR |
DWR_JMPR_ACTN |
DWR_JNT |
DWR_LD_AREA |
DWR_LD_BRK_SWTCH |
DWR_LD_GRP |
DWR_LD_RESPN_CHTRSTC |
DWR_LIFE_CYCL_DT |
DWR_LMT |
DWR_LMT_SET |
DWR_LN |
DWR_LOC |
DWR_LYLTY_PROG |
DWR_MEDIA_OBJ |
DWR_MEDIA_OBJ_ASGN |
DWR_MKT_AREA |
DWR_MKT_AREA_LVL |
DWR_MKT_PLN_DOC_REQRMNT |
DWR_MKT_RL |
DWR_MKT_SGMNT |
DWR_MKT_SGMNT_INCLSN |
DWR_MNFCTR |
DWR_MNTNR |
DWR_MSRMNT_LOC |
DWR_MSRMNT_VAL_QLTY |
DWR_MSRMNT_VAL_SRC |
DWR_MTR |
DWR_MTR_IDNT |
DWR_MTR_RGSTER_ASGN |
DWR_MTR_SRVC_WRK |
DWR_NAICS_CLSFCTN |
DWR_NON_CNFRM_LD |
DWR_NON_CNFRM_LD_GRP |
DWR_NON_CNFRM_LD_SCHL |
DWR_NUCLR_GNRTNG_UNIT |
DWR_OPERTNG_PRTCPNT |
DWR_OPERTNG_SHR |
DWR_OPRN_TAG |
DWR_OPRTNL_LMT |
DWR_OPRTNL_LMT_SET |
DWR_OPRTNL_RSTRCT |
DWR_ORCL_GMTRY |
DWR_ORG_AREA |
DWR_ORG_BNR |
DWR_ORG_BSNS_ENT |
DWR_ORG_BSNS_UNIT |
DWR_ORG_CHAIN |
DWR_ORG_CMPNY |
DWR_ORG_CRPRT |
DWR_ORG_DEMOG_VAL |
DWR_ORG_DSTRCT |
DWR_ORG_HRCHY |
DWR_ORG_HRCHY_LVL |
DWR_ORG_HRCHY_LVL_ASGN |
DWR_ORG_HRCHY_VRSN |
DWR_ORG_LVL |
DWR_ORG_LVL_ATRIB_VAL |
DWR_ORG_LVL_ATTR |
DWR_ORG_MKT_DATA |
DWR_ORG_RGN |
DWR_ORG_RL |
DWR_ORG_SRVC_WBSITE |
DWR_ORG_WRHS |
DWR_OTHR_INDVL |
DWR_OUTG_CD |
DWR_OUTG_NOTFCTN |
DWR_OUTG_PLN |
DWR_OUTG_REC_CD_ASGN |
DWR_OUTG_RPT |
DWR_OUTG_SCHL |
DWR_OUTG_STEP |
DWR_OUTG_STEP_CD_ASGN |
DWR_OUTG_USG_PNT_ASGN |
DWR_PBLCTN |
DWR_PER_LGTH_IMPNDNC |
DWR_PER_LGTH_PHS_IMPNDNC |
DWR_PER_LGTH_SEQ_IMPNDNC |
DWR_PHS_CNCTD_FLT |
DWR_PHS_IMPNDNC_DATA |
DWR_PHS_TAP_CHNG |
DWR_PHS_TAP_CHNG_ASYMTRCL |
DWR_PHS_TAP_CHNG_LNR |
DWR_PHS_TAP_CHNG_NON_LNR |
DWR_PHS_TAP_CHNG_SYMTRCL |
DWR_PHS_TAP_CHNG_TBLR |
DWR_PHS_TAP_CHNG_TBLR_PNT |
DWR_PIN_VLTG |
DWR_PLND_OUTG |
DWR_POLE |
DWR_POSTCD |
DWR_POWR_CUT_ZN |
DWR_POWR_SYS_RESRE_LOC |
DWR_POWR_TRNSFRMR |
DWR_POWR_TRNSFRMR_END |
DWR_POWR_TRNSFRMR_INFO |
DWR_PRCNG_STRCTR_TRF_ASGN |
DWR_PRCNG_STRUCTR |
DWR_PRIORITY |
DWR_PRMTN |
DWR_PRMTN_MSG_RNDRNG |
DWR_PRMTN_PROD_OFRNG_ASGN |
DWR_PRMTN_RLTN |
DWR_PRMTN_SL_CHNL_ASGN |
DWR_PROC |
DWR_PROC_ASST_ASGN |
DWR_PROD_ASST_MDL |
DWR_PROD_ASST_MDL_FNCTN_ASGN |
DWR_PROD_OFRNG |
DWR_PROD_SBRP |
DWR_PROJ |
DWR_PROJ_ELMNT |
DWR_PROTCTN_EQPMNT |
DWR_PROTCTN_EQPMNT_INFO |
DWR_PRPSL |
DWR_PRPSL_RLTN |
DWR_PRSPCT |
DWR_PRSPCT_QLTY_SCR_VAL |
DWR_PRTCTD_SWTCH |
DWR_PRTNR_PRMTN_PROG |
DWR_PRTY |
DWR_PRTY_ACCT_ASGN |
DWR_PRTY_ADDR_LOC_ASGN |
DWR_PRTY_AGRMNT_RLTN |
DWR_PRTY_ASGN |
DWR_PRTY_BSNS_INTRACN_RL |
DWR_PRTY_CNCT_INFO |
DWR_PRTY_GEO_ENT_ASGN |
DWR_PRTY_MKT_SGMNT_ASGN |
DWR_PRTY_PROJ_PRTCPTN |
DWR_PRTY_RL_ASGN |
DWR_PRTY_RL_STAT |
DWR_PTNTL_TRNSFRMR_INFO |
DWR_PYMT_CHNL |
DWR_RATE |
DWR_RATIO_TAP_CHNG |
DWR_RATIO_TAP_CHNG_TBLR |
DWR_RATIO_TAP_CHNG_TBLR_PNT |
DWR_RCLSR |
DWR_RDNG_CHNL |
DWR_RDNG_CHNL_IDNT |
DWR_RDNG_TYP |
DWR_REGULTN_SCHL |
DWR_RGLR_INTRVL_SCHL |
DWR_RGLR_TIME_PNT |
DWR_RGLTNG_CNTRL |
DWR_RGLTNG_COND_EQ |
DWR_RGSTER |
DWR_RMT_CNTRL |
DWR_RMT_CONCT_DSCNCT_INFO |
DWR_RMT_PNT |
DWR_RMT_SRC |
DWR_RMT_UNIT |
DWR_RMT_UNIT_COMUNCTN_LNK_ASGN |
DWR_ROTTNG_MC |
DWR_RTNL_NBR |
DWR_SB_GEOCL_RGN |
DWR_SB_LD_AREA |
DWR_SBSTN |
DWR_SCHL_EVT_ASST_ASGN |
DWR_SCRPT |
DWR_SCRPT_QUES |
DWR_SEAL |
DWR_SEASON_DAY_TYP_SCHL |
DWR_SECTNR |
DWR_SERIES_CMPNSTR |
DWR_SFTY_DOC |
DWR_SGMNT_CRTRA |
DWR_SHNT_CMPNSTR |
DWR_SHNT_CMPNSTR_INFO |
DWR_SHNT_CMPNSTR_PHS |
DWR_SIC_ASGN |
DWR_SL_CHNL |
DWR_SMPL_END_DVC_FNCTN |
DWR_SOC_JB |
DWR_SOC_JB_CTGRY |
DWR_SOC_JB_GRP |
DWR_SRC_SYS |
DWR_SRC_SYS_KEY_MAP |
DWR_SRG_ARSTR_INFO |
DWR_SRVC |
DWR_SRVC_COVRG_AREA |
DWR_SRVC_COVRG_GEO_DTL |
DWR_SRVC_LOC |
DWR_SRVC_LOC_IDNT |
DWR_SRVC_QTY |
DWR_SRVC_SPPLR |
DWR_STAT |
DWR_STATIC_VAR_CMPNSTR |
DWR_STEAM_SNDOUT_SCHL |
DWR_STN_SPPLY |
DWR_STRCTR |
DWR_STRCTR_SPPRT |
DWR_STREETLGHT |
DWR_SURVEY |
DWR_SWTCH |
DWR_SWTCH_ACTN |
DWR_SWTCH_ACTVTY_SFTY_DOC_ASGN |
DWR_SWTCH_CNCT_DSCNCT_FNC_ASGN |
DWR_SWTCH_INFO |
DWR_SWTCH_PHS |
DWR_SWTCH_SCHL |
DWR_SWTCH_SWTCHNG_OPRN_ASGN |
DWR_SWTCHNG_ACTVTY |
DWR_SWTCHNG_OPRN |
DWR_SWTCHNG_PLN |
DWR_SWTCHNG_STEP |
DWR_SWTCHNG_STEP_GRP |
DWR_SYNCHRCHCK_RLY |
DWR_SYNCHRNS_MC |
DWR_TAG_ACTN |
DWR_TAP_CHNG |
DWR_TAP_CHNG_CNTRL |
DWR_TAP_CHNG_INFO |
DWR_TAP_SCHL |
DWR_TASK |
DWR_THRML_GNRTNG_UNIT |
DWR_TIME_SCHL |
DWR_TIME_SLT |
DWR_TIME_TRF_INTRVL |
DWR_TOOL |
DWR_TPLGCL_ND |
DWR_TRBL_TCKT |
DWR_TRF |
DWR_TRF_PRFL |
DWR_TRF_TRF_PRFL_ASGN |
DWR_TRGT_ACCT |
DWR_TRGT_AGRMNT |
DWR_TRGT_GEO_AREA |
DWR_TRGT_MKT_SGMNT |
DWR_TRML |
DWR_TRNSFRMR_CORE_ADMTTNC |
DWR_TRNSFRMR_END |
DWR_TRNSFRMR_END_INFO |
DWR_TRNSFRMR_FEDR_ASGN |
DWR_TRNSFRMR_MESH_IMPNDNC |
DWR_TRNSFRMR_STAR_IMPNDNC |
DWR_TRNSFRMR_TANK |
DWR_TRNSFRMR_TANK_END |
DWR_TRNSFRMR_TANK_INFO |
DWR_TWR |
DWR_UNDRGRND_STRCTR |
DWR_USG_PNT |
DWR_USG_PNT_END_DVC_CTRL_ASGN |
DWR_USG_PNT_EQPMNT_ASGN |
DWR_USG_PNT_GRP |
DWR_USG_PNT_GRP_ASGN |
DWR_USG_PNT_GRP_DR_PROG_ASGN |
DWR_USG_PNT_LOC |
DWR_USG_PNT_TRNSFRMR_ASGN |
DWR_USG_PT_GP_END_DVC_CTL_ASGN |
DWR_USG_READ_CYCL |
DWR_VAL_ALS_SET |
DWR_VAL_TO_ALS |
DWR_VHCL |
DWR_VLTG_CNTRL_ZN |
DWR_VLTG_LMT |
DWR_VNDR |
DWR_VNDR_ITEM |
DWR_VRTL_TEAM |
DWR_WEB_PG |
DWR_WND_GNRTNG_UNIT |
DWR_WR_INFO |
DWR_WR_SPCNG_INFO |
DWR_WRK_ASST |
DWR_WRK_BLLG_INFO |
DWR_WRK_COST_DTL |
DWR_WRK_FLOW_STEP |
DWR_WRK_LOC |
DWR_WRK_ORDR |
DWR_WRK_STAT_ENTRY |
DWR_WRK_TASK |
DWR_WRK_TASK_AS_SET_ASGN |
DWR_WRK_TIME_SCHL |
DWR_ZN |
Table 4-4 briefly describes the Lookup tables in Oracle Utilities Data Model.
Table 4-4 Lookup Tables
DWL_ACCT_ADJ_RSN |
DWL_ACCT_ASGN_RSN |
DWL_ACCT_ASGN_TYP |
DWL_ACCT_BAL_ADJ_TYP |
DWL_ACCT_BAL_TYP |
DWL_ACCT_EVT_TYP |
DWL_ACCT_ITEM_CTGRY |
DWL_ACCT_PYMT_MTHD_STAT_RSN |
DWL_ACCT_PYMT_MTHD_STAT_TYP |
DWL_ACCT_RFND_RSN |
DWL_ACCT_RL_TYP |
DWL_ACCT_STAT_RSN |
DWL_ACCT_STAT_TYP |
DWL_ACCT_TYP |
DWL_AGRMNT_ASGN_RSN |
DWL_AGRMNT_ASGN_TYP |
DWL_AGRMNT_STAT_TYP |
DWL_AGRMNT_TYP |
DWL_AMI_BLLG_RDY_KIND_ENUM |
DWL_ANCHOR_KIND_ENUM |
DWL_APNMNT_TYP |
DWL_ASST_MDL_USG_KIND_ENUM |
DWL_ASST_TYP |
DWL_BARNG_RSN |
DWL_BLLG_OCCRNCE_TYP |
DWL_BLLG_PRD |
DWL_BSHNG_INSLTN_KIND_ENUM |
DWL_BSNS_INTRACN_ASGN_TYP |
DWL_BSNS_INTRACN_STAT_RSN |
DWL_BSNS_INTRACN_STAT_TYP |
DWL_BSNS_INTRACN_TYP |
DWL_BSNS_LEGAL_STAT |
DWL_CALL_CNTR_CASE_SB_TYP |
DWL_CALL_CNTR_CASE_TTL |
DWL_CALL_CNTR_CASE_TYP |
DWL_CHNL_TYP |
DWL_CHRG_KIND_ENUM |
DWL_CLRNCE_ACTN_KIND_ENUM |
DWL_CMPGN_CHNL_TYP |
DWL_CMPGN_STAT |
DWL_CMPGN_TYP |
DWL_CMPST_SWTCH_KIND_ENUM |
DWL_CNCT_LST_CHNG_RSN |
DWL_CNCT_LST_RCRNC_TYP |
DWL_CNCT_RLS |
DWL_CNTRL_TYP |
DWL_COLNT_TYP_ENUM |
DWL_COMUNICTN_DRCTN_KIND_ENUM |
DWL_COMUNICTN_TCHNLGY_KIND_ENUM |
DWL_COST_RSN |
DWL_COST_SB_TYP |
DWL_COST_TYP |
DWL_CRNCY |
DWL_CRNCY_ENUM |
DWL_CRPRT_STNDRD_KIND_ENUM |
DWL_CRVE_STYLE_ENUM |
DWL_CUST_GRP |
DWL_CUST_KIND_ENUM |
DWL_CUST_OCCSN_TYP |
DWL_CUST_RVN_BND |
DWL_CUST_TYP |
DWL_CUT_JMPR_ACTN_KIND_ENUM |
DWL_DAY_TYP |
DWL_DEBT_AGNG_BND |
DWL_DOC_TYP |
DWL_DOC_TYP_GRP |
DWL_DRCT_DEBT_STAT_RSN |
DWL_EDU |
DWL_EMP_DESIG |
DWL_EMP_JB_RL_TYP |
DWL_EMP_TYP |
DWL_END_DVC_DOMAIN |
DWL_END_DVC_EVT_OR_ACTN |
DWL_END_DVC_EVT_TYP |
DWL_END_DVC_FNCTN_KIND_ENUM |
DWL_END_DVC_SB_DOMAIN |
DWL_END_DVC_TYP |
DWL_ENRGY_FLOW_DRCTN |
DWL_EVT_ASGN_RSN |
DWL_EVT_ASGN_TYP |
DWL_EVT_CLASS |
DWL_EVT_CTGRY |
DWL_EVT_PRTY_RL |
DWL_EVT_RESPN_RSN |
DWL_EVT_RSLT |
DWL_EVT_RSLTN |
DWL_EVT_RSN |
DWL_EVT_RSN_CTGRY |
DWL_EVT_STAT_RSN |
DWL_EVT_STAT_TYP |
DWL_EVT_TYP |
DWL_EXTRNL_ORG_TYP |
DWL_FCT_DVC_KIND_ENUM |
DWL_FLT_IND_RESET_KIND_ENUM |
DWL_GL_ACCT_TYP |
DWL_GL_JE_CTGRY |
DWL_GL_SGMNT_TYP |
DWL_GNDR |
DWL_GNRTR_CNTRL_MD_ENUM |
DWL_GNRTR_CNTRL_SRC_ENUM |
DWL_GNRTR_OPERTNG_MD_ENUM |
DWL_HYDR_ENRG_CNVRSN_KIND_ENUM |
DWL_INTRACN_DRCTN |
DWL_INTRACN_PRIORITY_TYP |
DWL_INTRACN_RSLT_TYP |
DWL_INTRACN_RSN |
DWL_INTRACN_STAT |
DWL_INTRACN_TRNSFR_RSN |
DWL_INTRACN_TYP |
DWL_INTRHRMNCS |
DWL_INTTV_RSLT_TYP |
DWL_INTTV_TYP |
DWL_INVC_DISC_RSN |
DWL_INVC_DISC_TYP |
DWL_INVC_DLVRY_FRMT |
DWL_INVC_DLVRY_TYP |
DWL_INVC_ITEM_DTL_TYP |
DWL_INVC_ITEM_TYP |
DWL_INVC_PYMT_TERM_TYP |
DWL_INVC_STAT_TYP |
DWL_INVC_TYP |
DWL_IVR_MENU_ITEM |
DWL_JNT_CNFGRTN_KIND_ENUM |
DWL_JNT_FILL_KIND_ENUM |
DWL_LANG |
DWL_LTTR_TYP |
DWL_LYLTY_PROG_EVT_TYP |
DWL_MEDIA_OBJ_TYP |
DWL_MRTL_STAT |
DWL_MSRMNT_KIND |
DWL_MTR_STAT |
DWL_NTNLTY |
DWL_ORG_BSNS_UNIT_TYP |
DWL_PBLCTN_TYP |
DWL_PHS |
DWL_PHS_CD_ENUM |
DWL_PHS_CNCTD_FLT_KIND_ENUM |
DWL_PHS_SHNT_CNCTN_KIND_ENUM |
DWL_PLND_OUTG_KIND_ENUM |
DWL_POLE_BASE_KIND_ENUM |
DWL_POLE_PRSRVTV_KIND_ENUM |
DWL_POLE_TRTMNT_KIND_ENUM |
DWL_POSTL_SRVC_TYP |
DWL_PRICE_TYP |
DWL_PRMTN_RSLT_TYP |
DWL_PRMTN_TERM_TYP |
DWL_PRMTN_TERM_VAL |
DWL_PRMTN_TYP |
DWL_PROC_KIND_ENUM |
DWL_PRSPCT_PRIORITY_TYP |
DWL_PRSPCT_QLTY_SCR_TYP |
DWL_PRSPCT_REJECT_RSN |
DWL_PRTY_ACCT_ASGN_TYP |
DWL_PRTY_ASGN_RSN |
DWL_PRTY_ASGN_TYP |
DWL_PRTY_CNCT_INFO_TYP |
DWL_PRTY_CNCT_LST_PRTCPTN |
DWL_PRTY_CNCT_LST_RL |
DWL_PRTY_EVT_TYP |
DWL_PRTY_INTRACN_THRD_TYP |
DWL_PRTY_LOC_RSN |
DWL_PRTY_LOC_TYP |
DWL_PRTY_MGMT_RL |
DWL_PRTY_RL |
DWL_PRTY_STAT_CHNG_RSN |
DWL_PRTY_STAT_CTGRY |
DWL_PRTY_STAT_TYP |
DWL_PRTY_TYP |
DWL_PSR_TYP |
DWL_PYMT_AGNG_CLASS |
DWL_PYMT_MTHD_TYP |
DWL_PYMT_TRX_TYP |
DWL_RDNG_ACMLTN_BHVR |
DWL_RDNG_DATA_QLFR |
DWL_RDNG_QLTY_TYP |
DWL_RDNG_QLTY_TYP_CTGRY |
DWL_RDNG_QLTY_TYP_ORIGIN |
DWL_RDNG_QLTY_TYP_SB_CTGRY |
DWL_RDNG_RSN_KIND_ENUM |
DWL_RDNG_TIME_ATRIB |
DWL_RDNG_TIME_PRD |
DWL_RGLTNG_CNTRL_MD_KIND_ENUM |
DWL_RMT_UNIT_TYP_ENUM |
DWL_RVN_KIND_ENUM |
DWL_SEAL_CNDTN_KIND_ENUM |
DWL_SEAL_KIND_ENUM |
DWL_SEASON |
DWL_SGMNT_TYP |
DWL_SHORT_CRCUT_RTR_KIND_ENUM |
DWL_SIC_ASGN_RSN |
DWL_SIC_CLSFCTN |
DWL_SNCHRNS_MC_OPERTNG_MD_ENUM |
DWL_SNGL_PHS_KIND_ENUM |
DWL_SRC_ENUM |
DWL_SRC_SYS_TYP |
DWL_SRVC_CTGRY |
DWL_SRVC_TYP |
DWL_STRCTR_MTRL_KIND_ENUM |
DWL_STRCTR_SPPRT_KIND_ENUM |
DWL_STREETLGHT_LAMP_KIND_ENUM |
DWL_SVC_CNTRL_MD_ENUM |
DWL_SWTCH_ACTN_KIND_ENUM |
DWL_SWTCH_STATE_ENUM |
DWL_SYNCHRNS_MC_KIND_ENUM |
DWL_TAG_ACTN_KIND_ENUM |
DWL_TAX_AUTH |
DWL_TAX_CTGRY |
DWL_TIME_OF_USE |
DWL_TRBL_RPT_KIND_ENUM |
DWL_TRGT_TYP |
DWL_TRNSFRMR_CNTRL_MD_ENUM |
DWL_TWR_CONSTRCTN_KIND_ENUM |
DWL_UNDRGRND_STRCTR_KIND_ENUM |
DWL_UNIT_MLTPLR |
DWL_UNIT_MLTPLR_ENUM |
DWL_UNIT_SYMBL_ENUM |
DWL_UOM |
DWL_USG_PNT_CNCTD_KIND_ENUM |
DWL_UTLTY_CMDTY |
DWL_VAL_TYP |
DWL_VEE_EXPTN_TYP |
DWL_VEE_GRP |
DWL_VEE_RULE |
DWL_VLDTY_ENUM |
DWL_WEATHR_ALRT |
DWL_WEATHR_FRCST |
DWL_WEATHR_INFO |
DWL_WEATHR_LOC |
DWL_WND_GEN_UNIT_KIND_ENUM |
DWL_WNDNG_CNCTN_ENUM |
DWL_WR_INSLTN_KIND_ENUM |
DWL_WR_MTRL_KIND_ENUM |
DWL_WR_USG_KIND_ENUM |
DWL_WRK_KIND_ENUM |
DWL_WRK_STAT_KIND_ENUM |
DWL_WRK_TASK_KIND_ENUM |
DWL_WRK_TIME_SCHL_KIND_ENUM |
DWL_ZN_KIND_ENUM |
Table 4-5 briefly describes the Base tables in Oracle Utilities Data Model.
Table 4-5 Base Tables
DWB_ACCMLTR |
DWB_ACCMLTR_VAL |
DWB_ACCT_ACCT_CYCL_HIST |
DWB_ACCT_BAL_ADJ |
DWB_ACCT_BAL_BKT |
DWB_ACCT_BAL_HIST |
DWB_ACCT_BAL_IMPT |
DWB_ACCT_BLLG_OCCRNCE |
DWB_ACCT_CRDT_LMT |
DWB_ACCT_DEBT |
DWB_ACCT_MGMT_HIST |
DWB_ACCT_PYMT |
DWB_ACCT_PYMT_BAL_IMPT |
DWB_ACCT_PYMT_MTHD_STAT |
DWB_ACCT_RCHRG |
DWB_ACCT_RFND |
DWB_ACCT_STAT_HIST |
DWB_ACTVTY_REC |
DWB_AGRMNT_APRVL |
DWB_AGRMNT_ASGN |
DWB_AGRMNT_STAT |
DWB_ANLG |
DWB_ANLG_VAL |
DWB_APNMNT |
DWB_ASST_APPRSL_HIST |
DWB_ASST_CNDTN_HIST |
DWB_ATMSPHRC_PRSSR |
DWB_BLK_LST_HIST |
DWB_BSNS_INTRACN |
DWB_BSNS_INTRACN_ITEM |
DWB_BSNS_INTRACN_ITEM_PRICE |
DWB_BSNS_INTRACN_RL |
DWB_BSNS_INTRACN_STAT_HIST |
DWB_CLOUD_INFO |
DWB_CMND |
DWB_CMPGN_MSG_CRTVE |
DWB_CNFGRTN_EVT |
DWB_CNTRL |
DWB_COST |
DWB_CRNCY_EXCHNG_RATE |
DWB_CRVE_DATA |
DWB_CUST_ORDR |
DWB_CUST_ORDR_LI |
DWB_DEBT_COLLCTN |
DWB_DEBT_COLLCTN_ASGN |
DWB_DEBT_COLLCTN_ASGN_BTCH |
DWB_DOC_STAT |
DWB_DSCRT |
DWB_DSCRT_VAL |
DWB_EMP_ACT_LBR_HRLY |
DWB_EMP_COST |
DWB_EMP_TRNG_REC |
DWB_END_DVC_CNTRL |
DWB_END_DVC_CNTRL_PRMRY_DVC_TMNG |
DWB_END_DVC_CNTRL_SCNDRY_DVC_TMNG |
DWB_END_DVC_EVT |
DWB_EVT |
DWB_EVT_ACCT |
DWB_EVT_ASGN |
DWB_EVT_CHAT |
DWB_EVT_CHAT_DTL |
DWB_EVT_EMP_PYRL |
DWB_EVT_EQPMNT_INSTNC |
DWB_EVT_GEO |
DWB_EVT_INVC_DLVRY |
DWB_EVT_LYLTY_PROG |
DWB_EVT_PRTY_ASGN |
DWB_EVT_PRTY_INTRACN |
DWB_EVT_PRTY_INTRACN_CALL |
DWB_EVT_PRTY_INTRACN_EML |
DWB_EVT_PRTY_INTRACN_ITEM |
DWB_EVT_PRTY_INTRACN_LTTR |
DWB_EVT_PRTY_INTRACN_PRTCPTN |
DWB_EVT_PRTY_INTRACN_VST |
DWB_EVT_PRTY_PRFL |
DWB_EVT_STAT |
DWB_EVT_WEB_RGSTRTN |
DWB_EVT_WEB_VST |
DWB_FLOD_INFO |
DWB_FNL_RDNG |
DWB_GL_BAL |
DWB_GL_JE |
DWB_GL_JE_BTCH |
DWB_GL_JE_LN |
DWB_GL_JE_LN_SBLDGR_ASGN |
DWB_GL_SBLDGR_JE |
DWB_GL_SBLDGR_JE_LN |
DWB_INCDNT |
DWB_INITIAL_RDNG |
DWB_INTRACN_ANSWR_CHOICE |
DWB_INTRACN_NAVGTN_HIST |
DWB_INTRACN_QUES_RESPN |
DWB_INTRACN_TRNSFR_HIST |
DWB_INVC |
DWB_INVC_ADJ |
DWB_INVC_DISC |
DWB_INVC_ITEM |
DWB_INVC_ITEM_DTL |
DWB_INVC_ITEM_RLTN |
DWB_INVC_PYMT_ASGN |
DWB_INVC_PYMT_TERM |
DWB_INVC_STAT_HIST |
DWB_INVC_TAX_ITEM |
DWB_JE_LN_INVC_ITEM_ASGN |
DWB_MSRMNT |
DWB_MSRMNT_VAL |
DWB_MTR_RDNG |
DWB_OUTG |
DWB_OUTG_REC |
DWB_PCHSE_ORDR |
DWB_PCHSE_ORDR_LI |
DWB_PPTN |
DWB_PRICE_EVT |
DWB_PRMTN_CLSTR_USG |
DWB_PRMTN_CNCT_LST_UTLZTN |
DWB_PRMTN_MGMT_HIST |
DWB_PRTY_COST_ASGN |
DWB_PRTY_INTRACN_THRD |
DWB_PRTY_INTRCN_THRD_SBRP_ASGN |
DWB_PRTY_PRMTN_RESPN |
DWB_PRTY_STAT_HIST |
DWB_RDNG_QLTY |
DWB_RESRE_ORDR |
DWB_RESRE_ORDR_ITEM |
DWB_SCHL_EVT |
DWB_SEA_CNDTN |
DWB_SET_PNT |
DWB_SPOT_TEMP |
DWB_SRVC_ORDR |
DWB_SRVC_ORDR_LI |
DWB_STRNG_MSRMNT |
DWB_STRNG_MSRMNT_VAL |
DWB_VEE_EXPTN |
DWB_WND_INFO |
DWB_WRK_COST_SUMM |
Not physicalized |
Table 4-6 Oracle Utilities Data Model Derived Tables
DWD_ACCT_ARRER_MO |
DWD_ACCT_BAL_MO |
DWD_ACCT_DEBT_DAY |
DWD_ACCT_PYMT_DAY |
DWD_ACCT_PYMT_MTHD_STAT_HIST |
DWD_ACCT_STAT_MO |
DWD_CUST_MNNG |
DWD_DR_PROG_LD_RDCTN_RGN_DAY |
DWD_END_DVC_EVT_CUST_DAY |
DWD_END_DVC_EVT_DVC_DAY |
DWD_MTR_RDNG_DAY |
DWD_MTR_RDNG_HR |
DWD_OUTG_DAY |
DWD_OUTG_USG_PNT |
DWD_RLBLTY_IND_CITY_MO |
DWD_RLBLTY_IND_FEDR_MO |
Table 4-7 briefly describes the Aggregate tables in Oracle Utilities Data Model.
Table 4-7 Aggregate Tables
DWA_END_DVC_EVT_CUST_MO |
DWA_END_DVC_EVT_DVC_MO |
DWA_MTR_RDNG_MO |
DWA_MTR_RDNG_TOU_MO |
DWA_OUTG_MO |
Briefly describes the temporary and control tables in Oracle Utilities Data Model.
Table 4-8 and Table 4-9 briefly describes the temporary and control tables in Oracle Utilities Data Model.
Table 4-8 Temporary Oracle Utilities Data Model Tables
| Table Name | Description |
This entity gives order measures, number of orders and total order amount, in same quarters of consecutive years. |
This entity gives order measures, number of orders and total order amount, in consecutive quarters. |
This entity summarizes orders placed by customers at month level aggregation. Using this entity, order measures, number of orders and total order amount, across order status, order type, product, product type dimensions can be computed. |
TMP_DWD_CUST_RFMP_SCR_1 |
No value |
TMP_DWD_CUST_RFMP_SCR_2 |
No value |
Table 4-9 Control Tables
Store ETL parameters such as etl start date and etl end date. For more information, see "Intra-ETL Load Parameters Control Table". |
Reports errors at the individual program level. For more information, see "Intra-ETL Monitoring Process Control Tables". |
Reports errors at the whole batch load level. For more information, see "Intra-ETL Monitoring Process Control Tables". |
Reports OLAP ETL parameter. For more information, see "Intra-ETL OLAP Mapping Control Table". |
Table 4-10 lists the sequence names in Oracle Utilities Data Model.
Table 4-10 Sequence Name for Oracle Utilities Data Model
| Table Name | Sequence Name |
DWC_INTRA_ETL_ACTIVITY |
INTRA_ETL_ACTIVITY_SEQ |
DWC_INTRA_ETL_PROCESS |
INTRA_ETL_PROCESS_SEQ |
DWR_CUST_SGMNT |
CUST_SGMNT_SEQ |
This section lists the Compressed Tables in Oracle Utilities Data Model. Oracle Utilities Data Model uses Database Compression on these tables to save space and load times.
DWA_MTR_RDNG_MO
DWA_MTR_RDNG_MO_ACCT
DWA_MTR_RDNG_MO_CUST
DWA_MTR_RDNG_MO_UP
DWA_MTR_RDNG_TOU_MO
DWA_OUTG_MO
DWB_ACCT_BAL_ADJ
DWB_ACCT_BAL_HIST
DWB_ACCT_CRDT_LMT
DWB_ACCT_PYMT
DWB_ACCT_RFND
DWB_ACCT_STAT_HIST
DWB_AGRMNT_APRVL
DWB_AGRMNT_STAT
DWB_BLK_LST_HIST
DWB_BSNS_INTRACN
DWB_CMPGN_MSG_CRTVE
DWB_COST
DWB_CUST_ORDR
DWB_CUST_ORDR_LI
DWB_DEBT_COLLCTN
DWB_EMP_COST
DWB_EMP_TRNG_REC
DWB_END_DVC_EVT
DWB_EVT
DWB_EVT_ACCT
DWB_EVT_ASGN
DWB_EVT_EMP_PYRL
DWB_EVT_GEO
DWB_EVT_INVC_DLVRY
DWB_EVT_LYLTY_PROG
DWB_EVT_PRTY_ASGN
DWB_EVT_PRTY_PRFL
DWB_EVT_STAT
DWB_EVT_WEB_RGSTRTN
DWB_EVT_WEB_VST
DWB_FNL_RDNG
DWB_INCDNT
DWB_INITIAL_RDNG
DWB_INVC
DWB_INVC_ADJ
DWB_INVC_DISC
DWB_INVC_ITEM
DWB_INVC_ITEM_DTL
DWB_INVC_PYMT_ASGN
DWB_INVC_STAT_HIST
DWB_MTR_RDNG
DWB_OUTG
DWB_OUTG_REC
DWB_PRICE_EVT
DWB_PRMTN_CLSTR_USG
DWB_PRMTN_MGMT_HIST
DWB_PRTY_COST_ASGN
DWB_PRTY_STAT_HIST
DWB_RESRE_ORDR
DWB_SRVC_ORDR
DWD_ACCT_ARRER_MO
DWD_ACCT_BAL_MO
DWD_ACCT_DEBT_DAY
DWD_ACCT_PYMT_DAY
DWD_ACCT_STAT_MO
DWD_CUST_DR_PROG_PROFILE
DWD_MTR_RDNG_DAY
DWD_MTR_RDNG_HR
DWD_OUTG_DAY
DWD_OUTG_USG_PNT
DWR_SRVC_QTY
This section includes information on the following:
Oracle OLAP Cube Views: Oracle OLAP cube views provide organizations with the ability to both improve the performance and analytic content of SQL-based business intelligence applications. OLAP cube views are relational views of OLAP cubes, dimensions, and hierarchies that reveal the full content of cubes and dimensions.
Cube MV (Materialized Cube Views): Cube-organized materialized views, introduced, in Oracle Database 11g, play the same role as table-based materialized views. That is, a summary management solution that is transparent to the querying application. Like table-based materialized views, the application queries the detail tables and the database automatically rewrites the query to access summary data in the materialized view. In the case of cube-organized materialized views, the data is managed in the cube rather than a table.
Table 4-11 shows the cube materialized views in oudm_sys schema.
Table 4-11 OLAP Cube Materialized Views in oudm_sys Schema
| Cube Materialized View Name | OLAP Object Name | OLAP Object Type |
Cube |
Table 4-12 shows the OLAP cube views in oudm_sys schema.
Table 4-12 OLAP Cube Views in oudm_sys schema
| Cube View Name | OLAP Object Name | OLAP Object Type |
Dimension |
Hierarchy |
