Environmental
Specifications
Oracle 6.4 TB NVMe SSDs operate and are stored in an environment defined by the parameters and
specifications in the following table.
Operating temperature
0 to 35°C ambient, 0 to 70°C case with specified
airflow
Operational environment: 5°C to 35°C (dry bulb)
Non-operating temperature
Storage and transit environment: –55°C to 95°C (dry
bulb)
Temperature monitoring
Temperature monitoring in-band and by way of SMBUS
Thermal throttling when approaching maximum composite
throttling temperature
See Troubleshooting Oracle 6.4 TB NVMe SSD Cooling for more information
on thermal throttling.
Thermal shutdown when drive exceeds maximum component
temperature
Dry bulb temperature
Maximum dry bulb temperature is derated by 3.3°C per 1000 m
above 500 m
Altitude (Simulated)
Operating: -1,000 to 10,000 ft
Non-operating: -1,000 to 40,000 ft
Relative humidity range
Operational environment: 8% to 80%
noncondensing
Storage and transit environment: 5% to 95%
noncondensing
Non-operating: -20°C to 75°C noncondensing
Thermal sensors
Airflow requirement
More than 450 LFM (linear feet/minute) at 25/35°C, airflow
towards the connector
Note -
For specific site planning guidelines and best practices, refer to the server documentation
and product notes for your server. Refer to the system site planning guide, if available.
