Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel Open UI > Reference Information for Siebel Open UI > Life Cycle Flows of User Interface Elements > Life Cycle Flows That Handle User NavigationThis topic describes the life cycle flows that Siebel Open UI uses when the user navigates through various items in the client. Figure 44 illustrates the life cycle flow that Siebel Open UI uses if the user clicks an applet in a view. Figure 44. Flow That Siebel Open UI Uses if the User Clicks an Applet in a ViewFigure 45 illustrates the that Siebel Open UI uses if the user navigates to a view. Figure 45. Flow That Siebel Open UI Uses if the User Navigates to a ViewFigure 46 illustrates the life cycle flow that Siebel Open UI if the focus changes for a field in a form applet. For example, if the user tabs out a field, clicks outside the field, minimizes the window, saves the record, and so on. Figure 46. Flow That Handles Focus Changes in Form AppletsFigure 47 illustrates the life cycle flow that Siebel Open UI if the focus changes for a field in a list applet. For example, if the user tabs out a field, clicks outside the field, minimizes the window, saves the record, and so on. Figure 47. Flow That Handles Focus Changes in List Applets |
Configuring Siebel Open UI | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
