| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
A field is a location in a record in which a particular type of data is stored. For example, a contact record might contain the following fields: last name, first name, address, and phone number. A field is characterized by its maximum length and the type of data (for example, numeric or alphabetic) it can contain.
In the application, required fields have an asterisk (a star icon) next to the field name. You cannot save a record until you enter data in the required fields.
If a field is disabled, then the field is read-only, and you cannot change the field content.
