| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You access the currency calculator by clicking the dollar sign button that appears in a field for a currency amount. You can use the currency calculator to specify financial transaction information in foreign currencies.
Figure 4-8 shows an example of the currency calculator.
Table 4-3 describes each field control in the currency calculator.
Table 4-3 Description of Currency Calculator Fields
| Field | Field Control | Description |
Currency Code |
Single select button |
Launches a dialog box where you can select the country and currency code. |
Exchange Date |
Calendar select button |
Launches the calendar control where you can select the exchange date. The field does not appear in all currency calculators. For more information, see "Calendar Control". |
Amount |
Calculator button |
Launches the calculator where you can enter the amount. You can also type the amount directly into the field. For more information, see "Calculator". |
