| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Use the following procedure to manually accept an incoming chat. You must manually accept incoming chats when chat auto answer is disabled.
To accept an incoming chat manually
Click the flashing Accept Work Item button on the communications toolbar.
A chat pane opens in an action pane of your Call Center application. The chat dashboard is prepopulated with the information provided by the user on the chat request form. The customer dashboard also opens, showing customer information.
Respond to the incoming chat as described in "Responding to an Incoming Chat".
For more information about accepting incoming chats and chat auto answer, see Siebel Chat Guide.
