| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 20-3 lists the keyboard shortcuts you can use to navigate in your application.
Table 20-3 General Navigation Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Go to the Site Map. |
Application |
Go to the application-level menu. |
Application |
Go to screen tabs. |
Note that CTRL+SHIFT+T is the shortcut, but for JAWS users it is recommended that you use the INSERT+CTRL+R Region List command. |
Application |
Go to the view tabs. |
Note that CTRL+ALT+T is the shortcut, but for JAWS users it is recommended that you use the INSERT+CTRL+R Region List command. |
Application |
Go to the subview tabs. |
Note that CTRL+ALT+V is the shortcut, but for JAWS users it is recommended that you use the INSERT+CTRL+R Region List command. |
Application |
Open the Menu (cogwheel icon) on a list or form. |
List, form |
Go to the next list or form. |
Application |
Go to the previous list or form. |
Application |
Open the Tasks pane. |
Application |
Go to a tree applet. |
Application |
Go to the previous tree applet node. |
Application |
Go to the next tree applet node. |
Application |
Go to the field for the visibility filter. |
Application |
