Go to primary content
Siebel CRM Fundamentals Guide
Siebel Innovation Pack 2017, Rev. A
E52425-01
  Go to Documentation Home
Home
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
    View PDF
Layout Management Keyboard Shortcuts
Table 20-4 lists the keyboard shortcuts you can use to change the appearance of lists in your application.
Table 20-4 Layout Management Keyboard Shortcuts
Action Keyboard Shortcut Context
Sort a single column.
  • ENTER
List column header
Open a dialog box to perform advanced sorting.
  • CTRL+SHIFT+O
List
Open a dialog box to select the displayed columns.
  • CTRL+SHIFT+K
  • CTRL+SHIFT+B
List
