| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 20-5 lists the keyboard shortcuts you can use when performing record management tasks in your application.
Table 20-5 Record Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Create a new record. |
List, form |
Create a new record using a Quick Fill template. |
Form |
Create a new record using the last used Quick Fill template. |
Form |
Apply a Quick Fill template to a record. |
Form |
Copy a record. |
Record |
Save a record. |
Note that if you use this shortcut to save a record that has an invalid value in a field, then the Save As dialog box may appear in error. In Mozilla Firefox and Google Chrome, you will be prompted to check if your data is in the correct format. |
List, form |
Delete a record. |
Record |
Undo a record. |
Record |
Select all records. |
List |
