| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 20-8 lists the keyboard shortcuts you can use when performing field management tasks in your application.
Table 20-8 Field Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Open a selection dialog box for a field. Open the calendar control for a field. Open the calculator control for a field. |
Field |
Close a selection dialog box for a field. |
Field |
Open a drop-down list for a field. |
Field |
Drill down on a field. |
Field |
