| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 20-9 lists the keyboard shortcuts you can use to share information with others in your application.
Table 20-9 Communication Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Go to the Correspondence screen to send a letter. |
Record |
Open a dialog box to send an email. |
Record |
Open a dialog box to send a fax. |
Record |
Open a dialog box to send a page. |
Record |
Open a dialog box to send an outbound wireless message. |
Record |
View a work item. |
Record |
Set work mode to ready. |
Record |
Set work mode to not ready. |
Record |
Set work mode to other. |
Record |
Set work mode to after call work. |
Record |
Set work mode to busy. |
Record |
