| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Provided that you install and deploy the Outlook to Siebel Drag and Drop addin (see Article ID 2117212.1 on My Oracle Support), then you can directly attach emails or email attachments from your Microsoft Outlook email client to records in your Siebel application. This improves the usability and productivity of call center agents.
To attach Microsoft Outlook emails or email attachments to records
Download the Outlook to Siebel Drag and Drop addin, and then double click Outlook_Add-in_for_Siebel.exe to install the addin.
Restart Microsoft Outlook for the addin to take effect. In the Microsoft Office client, verify that the Outlook to Siebel Drag and Drop addin is installed successfully.
Note: In Siebel Innovation Pack 2017, support for Outlook to Siebel Drag and Drop has been enhanced. For more information, see the topic about Installing Outlook to Siebel Drag and Drop on Client Computers in Siebel Installation Guide for the operating system you are using. |
Log in to your application.
Navigate to the Activities screen, drill down on the activity to which you want to attach emails or email attachments, and then go to the Attachments view for the selected activity.
The Attachments list appears.
Now go to your Microsoft Outlook email client and locate the emails or email attachments that you want to attach to the activity record in your application.
With both your application and the Microsoft Outlook email client open on-screen, do one or more of the following as required:
Select one single email from Microsoft Outlook and with the mouse button depressed, move the email into your application and then release the mouse button.
Select multiple emails from Microsoft Outlook and with the mouse button depressed, move the emails into your application and then release the mouse button.
Select an email attachment from Microsoft Outlook and with the mouse button depressed, move the email attachment into your application and then release the mouse button.
Any Microsoft Outlook emails or email attachments that you attach to records in your application appear in the Attachments list.
