| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
When an alarm appears on your screen, you can postpone or dismiss it. When you postpone it, you can specify the length of time for the alarm snooze. In your user preferences, you can set a default for the alarm snooze time in all of the activities you create. For more information, see "Default Alarm Snooze Times".
You can postpone an alarm in the Alarm dialog box.
To postpone an alarm
In the Alarm dialog box, choose the length of time for which you want to postpone the alarm from the drop-down list for the Snooze For field.
Click Snooze to postpone the alarm.
The alarm appears again after the amount of time you specify passes.
You can dismiss an alarm in the Alarm dialog box.
To dismiss an alarm
In the Alarm dialog box, click Dismiss to close the alarm.
The alarm does not appear again for the activity.
Note: If multiple alarms appear before you either postpone or dismiss them, then they are all queued behind the same alarm dialog box. You can click the Previous and Next buttons to move to each alarm. You can also click Dismiss All to dismiss every alarm that is currently active, or you can click Snooze All to postpone every alarm that is currently active. |
