| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The following procedure shows you how to modify the search settings for Oracle Secure Enterprise Search.
To modify the search settings for Oracle Secure Enterprise Search
Select Search Settings in the Search Toolbar and modify the settings as required
The following table describes the settings that you can modify.
| Setting | Description |
| Default Sort | Use the following options to sort the results:
| Language | Select a language to enable searching on keywords in a specific language. English is the default search language. |
| Fetch Language Specific Docs | Select this option to exclude search result records that are not in the selected language. |
