Siebel Pricing Administration Guide > Siebel Pricer Technical Reference > Modifying Signals from Basic Pricing Procedure to Dynamic Pricing Procedure >
Manual Signal Modifications for Siebel Business Applications and Industry Applications
NOTE: If you automatically enable the Dynamic Pricing Procedure for all signals as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure, then you do not need to implement any of the modifications outlined in this topic.
This topic lists the manual signal modifications required to implement dynamic pricing for Siebel Business Applications and Industry Applications. For each signal definition, you can modify the parameters of the actions listed. If multiple actions are listed for the signal, then make sure that you modify the parameters for each of the actions listed. NOTE: In some cases, the signal definition includes additional actions and parameters that are not listed. The following actions and parameters are the only ones that must be changed to implement dynamic pricing.
CalculatePriceAndCheckEligibility
Table 26 describes the signal action, and Table 27 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceAndCheckEligibility signal.
Table 26. CalculatePriceAndCheckEligibility Signal Action
Action |
Workflow |
PSP Driver Workflow Process |
Table 27. CalculatePriceAndCheckEligibility Parameters for Modification
SubPSPPricingWFName |
Dynamic Pricing Procedure |
Variable Map - Row Set |
Default Pricing Eligibility Variable Map - Row Set |
QuotesAndOrdersValidate
Table 28 describes the signal actions, and Table 29 lists the parameters that you must modify to implement dynamic pricing for the QuotesAndOrdersValidate signal. NOTE: Make sure you change the parameters for each of the four actions listed.
Table 28. QuotesAndOrdersValidate Signal Action
Action |
Workflow |
Order |
Header |
Workflow |
Order |
Line Item |
Workflow |
Quote |
Header |
Workflow |
Quote |
Line Item |
Table 29. QuotesAndOrdersValidate Parameters for Modification
Verifyitem
Table 30 describes the signal actions, and Table 31 lists the parameters that you must modify to implement dynamic pricing for the Verifyitem signal. NOTE: Make sure you change the parameters for each of the three actions listed.
Table 30. Verifyitem Signal Actions
Action |
Workflow |
Agreement |
Header |
Workflow |
Order |
Header |
Workflow |
Order |
Header |
Table 31. Verifyitem Parameters for Modification
ProductRecommendation
Table 32 describes the signal action, and Table 33 lists the parameter that you must modify to implement dynamic pricing for the ProductRecommendation signal.
Table 32. Product Recommendation Signal Action
Action |
Workflow |
Product Recommendation Driver Workflow |
Not applicable |
Line Item |
Table 33. ProductRecommendation Parameter for Modification
CalculatePriceExternal
Table 34 describes the signal action, and Table 35 lists the parameter that you must modify to implement dynamic pricing for the CalculatePriceExternal signal.
Table 34. CalculatePriceExternal Signal Action
Action |
Business Service |
RunPricerWorkflow |
Not applicable |
Not applicable |
Table 35. CalculatePriceExternal Parameter for Modification
SpreadDiscount
Table 36 describes the signal action, and Table 37 lists the parameter that you must modify to implement dynamic pricing for the SpreadDiscount signal.
Table 36. SpreadDiscount Signal Action
Action |
Workflow |
Spread Discount Driver Workflow Process |
Not applicable |
Not applicable |
Table 37. SpreadDiscount Parameter for Modification
SpreadDiscount - All
Table 38 describes the signal action, and Table 39 lists the parameter that you must modify to implement dynamic pricing for the SpreadDiscount - All signal.
Table 38. SpreadDiscount - All Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 39. SpreadDiscount - All Parameter for Modification
Approveitem
Table 40 describes the signal actions, and Table 41 lists the parameters that you must modify to implement dynamic pricing for the Approveitem signal. NOTE: Make sure you change the parameters for each of the three actions listed.
Table 40. Approveitem Signal Actions
Action |
Workflow |
Agreement |
Header |
Workflow |
Order |
Header |
Workflow |
Quote |
Header |
Table 41. Approveitem Parameters for Modification
SubPSPWFName |
Default Pricing Variable Map - Row Set |
CalculatePrice
Table 42 describes the signal action, and Table 43 lists the parameters that you must modify to implement dynamic pricing for the CalculatePrice signal.
Table 42. CalculatePrice Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 43. CalculatePrice Parameters for Modification
SubPSPWFName |
CalculatePriceAll
Table 44 describes the signal action, and Table 45 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceAll signal.
Table 44. CalculatePriceAll Signal Action
Action |
Workflow |
Not applicable |
Line Item |
Table 45. CalculatePriceAll Parameters for Modification
SubPSPWFName |
CalculatePrice_eSales
Table 46 describes the signal action, and Table 47 lists the parameters that you must modify to implement dynamic pricing for the CalculatePrice_eSales signal.
Table 46. CalculatePrice_eSales Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 47. CalculatePrice_eSales Parameters for Modification
SubPSPWFName |
CalculatePriceAll_eSales
Table 48 describes the signal action, and Table 49 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceAll_eSales signal.
Table 48. CalculatePriceAll_eSales Signal Action
Action |
Workflow |
Not applicable |
Line Item |
Table 49. CalculatePriceAll_eSales Parameters for Modification
SubPSPWFName |
CalculatePrice_Configurator
Table 50 describes the signal action, and Table 51 lists the parameters that you must modify to implement dynamic pricing for the CalculatePrice_Configurator signal.
Table 50. CalculatePrice_Configurator Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 51. CalculatePrice_Configurator Parameters for Modification
SubPSPWFName |
CalculatePrice_Advisor
Table 52 describes the signal action, and Table 53 lists the parameters that you must modify to implement dynamic pricing for the CalculatePrice_Advisor signal.
Table 52. CalculatePrice_Advisor Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 53. CalculatePrice_Advisor Parameters for Modification
SubPSPWFName |
MergeIntoOnePackage
Table 54 describes the signal action, and Table 55 lists the parameters that you must modify to implement dynamic pricing for the MergeIntoOnePackage signal.
Table 54. MergeIntoOnePackage Signal Action
Action |
Workflow |
Not applicable |
Line Item |
Table 55. MergeIntoOnePackage Parameters for Modification
SubPSPWFName |
OrderTemplate
Table 56 describes the signal actions, and Table 57 lists the parameters that you must modify to implement dynamic pricing for the OrderTemplate signal. NOTE: Make sure you change the parameters for each of the two actions listed.
Table 56. OrderTemplate Signal Actions
Action |
Workflow |
Order |
Header |
Workflow |
Quote |
Header |
Table 57. OrderTemplate Parameters for Modification
SubPSPWFName |
OrderTemplateCopy
Table 58 describes the signal actions, and Table 59 lists the parameters that you must modify to implement dynamic pricing for the OrderTemplateCopy signal.
Table 58. OrderTemplateCopy Signal Actions
Action |
Workflow |
Order |
Header |
Table 59. OrderTemplateCopy Parameters for Modification
SubPSPWFName |
OrderTemplateSelectItems
Table 60 describes the signal action, and Table 61 lists the parameters that you must modify to implement dynamic pricing for the OrderTemplateSelectItems signal.
Table 60. OrderTemplateSelectItems Signal Action
Action |
Workflow |
Order |
Header |
Table 61. OrderTemplateSelectItems Parameters for Modification
SubPSPWFName |
QuoteTemplateCopy
Table 62 describes the signal action, and Table 63 lists the parameters that you must modify to implement dynamic pricing for the QuoteTemplateCopy signal.
Table 62. QuoteTemplateCopy Signal Action
Action |
Workflow |
Quote |
Header |
Table 63. QuoteTemplateCopy Parameters for Modification
SubPSPPWFName |
QuoteTemplateSelectItems
Table 64 describes the signal action, and Table 65 lists the parameters that you must modify to implement dynamic pricing for the QuoteTemplateSelectItems signal.
Table 64. QuoteTemplateSelectItems Signal Action
Action |
Workflow |
Quote |
Header |
Table 65. QuoteTemplateSelectItems Parameters for Modification
SubPSPPWFName |
SetFieldValue
Table 66 describes the signal actions, and Table 67 lists the parameters that you must modify to implement dynamic pricing for the SetFieldValue signal. NOTE: Make sure you change the parameters for each of the four actions listed.
Table 66. SetFieldValue Signal Actions
Action |
Workflow |
Not applicable |
Header |
Workflow |
Agreement |
Line Item |
Workflow |
Order |
Line Item |
Workflow |
Quote |
Line Item |
Table 67. SetFieldValue Parameters for Modification
SubPSPWFName |
NOTE: The following fields are available for the Agreement, Order, and Quote actions: Product, Quantity Requested, Unit Price, Discount Amount, Discount Percent, Prod Prom Name, Currency Code, Item Price List, Covered Product Net Price. Fields available for the Header instance type are: Discount, Price List, and Currency Code.
GetConfigItemPrice
Table 68 describes the signal action, and Table 69 lists the parameter that you must modify to implement dynamic pricing for the GetConfigItemPrice signal.
Table 68. GetConfigItemPrice Signal Action
Action |
Workflow |
Get Config Item Price - Driver Workflow |
Not applicable |
Not applicable |
Table 69. GetConfigItemPrice Parameter for Modification
SubPSPWFName |
Get Config Item Price - Dynamic |
GetProdPrice
Table 70 describes the signal action, and Table 71 lists the parameters that you must modify to implement dynamic pricing for the GetProdPrice signal.
Table 70. GetProdPrice Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 71. GetProdPrice Parameters for Modification
SubPSPWFName |
Product Pricing Variable Map - Row Set |
GetUsedProdPrice
Table 72 describes the signal action, and Table 73 lists the parameters that you must modify to implement dynamic pricing for the GetUsedProdPrice signal.
Table 72. GetUsedProdPrice Signal Action
Action |
Workflow |
Not applicable |
Not applicable |
Table 73. GetUsedProdPrice Parameters for Modification
SubPSPWFName |
