Siebel Pricing Administration Guide > Siebel Pricer Technical Reference > Modifying Signals from Basic Pricing Procedure to Dynamic Pricing Procedure > Manual Signal Modifications for Communications, Media and Energy ApplicationsNOTE: If you automatically enable the Dynamic Pricing Procedure for all price lists as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure, then you do not need to implement any of the modifications outlined in this topic. This topic lists the manual signal modifications required to implement dynamic pricing for Siebel Communications, Media and Energy (CME) applications. NOTE: If you are using tiered pricing, then the following signals should refer to Pricing Procedure - CME. CalculatePriceCMETable 74 describes the signal action, and Table 75 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceCME signal.
CalculatePriceAllCMETable 76 describes the signal action, and Table 77 lists the parameters that you must modify to implement dynamic pricing for the CalculatePriceAllCME signal.
SaveWaterfall-QuoteTable 78 describes the signal action, and Table 79 lists the parameter that you must modify to implement dynamic pricing for the SaveWaterfall-Quote signal.
SaveWaterfall-OrderTable 80 describes the signal action, and Table 81 lists the parameter that you must modify to implement dynamic pricing for the SaveWaterfall-Order signal.
SaveWaterfall-ServiceAgreementTable 82 describes the signal action, and Table 83 lists the parameter that you must modify to implement dynamic pricing for the SaveWaterfall-ServiceAgreement signal.
| Siebel Pricing Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
