Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating Product Class Display Names
You can enter translations of the names of product classes, so they are displayed in the language of the end user. To translate a class display name
- Navigate to the Administration - Product screen, then the Product Classes view.
- Select and lock product class whose attributes you want to translate.
- In the Versions list, click the Work Space version.
- Click the Display Name view tab.
- Add a new record to the Display Name list and complete the necessary fields, described in the following table.
Display Name |
Enter the translation of the display name. |
Language |
Select a language code. |
- Repeat Step 5 to create additional language translations for the class display name.
