Go to main content
man pages section 3: Extended Library Functions, Volume 4
Exit Print View
Updated: Wednesday, July 27, 2022
sstore_info_read (3SSTORE)
Name
sstore_info_read, sstore_info_iter_next - Read meta information about statistics store identifiers.
Synopsis
    cc [ flag... ] file... -lsstore [ library... ]
     #include <libsstore.h>
     sstore_err_t sstore_info_read(sstore_handle_t hdl,
         const char **ids, uint32_t id_count,
         sstore_range_t range, sstore_iter_t *iterp);
     sstore_err_t sstore_info_iter_next(sstore_handle_t hdl,
         sstore_iter_t iter, char **idp, uint64_t *timep,
         sstore_value_t *valp);
Parameters
hdl
Handle to libsstore
ids
Array of statistics store identifiers
id_count
Total number of statistics store identifiers
range
Time range or data range.
Passing NULL for range implies:
  • start-time = SS_TIME_NOW
  • end-time = SS_TIME_NOW
  • step = 1
iterp
Address to store the starting address of the iterator.
iter
Iterator returned from data_read().
idp
Address to store the starting address of the statistics store identifier.
timep
Address to store the time in microseconds since epoch.
valp
Address to store the handle to a typed value.
Description
sstore_info_read() retrieves the metadata associated with the given identifiers and range. The retrieved data is returned in the form of an iterator that can be used to read the information records. When all the information records have been read from the iterator, use sstore_iter_free(3SSTORE) to free the iterator.
sstore_info_iter_next() retrieves the next information record of the iteration. Each information record consists of a statistics store identifier, a time stamp, and a value. The reference pointers passed to this call are populated if the call succeeds. The identifier, the time stamp, and the value populated on success do not need to be freed. They will be freed on the next call to sstore_info_iter_next().
Return Values
Upon successful completion, sstore_info_read() and sstore_info_iter_next() return ESSTORE_OK. Otherwise, they return an error code, which is also cached in the given libsstore handle.
Errors
The sstore_info_read() function will fail if:
ESSTORE_ARG_INVALID
One of the following reasons:
  • All the ssids are invalid.
  • All the ssids are inactive.
  • The range is not valid.
  • The fmt is not valid.
  • Required arguments are missing.
ESSTORE_HANDLE_INVALID
The handle is invalid
ESSTORE_RETRY
The statistics store daemon is busy. Retry later
ESSTORE_CONNECTION_FAILED
Failed to connect to the statistics store daemon
ESSTORE_TOO_BIG
The total size of all the resulting statistics records is larger than the maximum size limit set in libsstore.
ESSTORE_NOMEM
No memory is available.
The sstore_info_iter_next() function will fail if:
ESSTORE_ARG_INVALID
Some arguments are invalid.
ESSTORE_ITER_DONE
No more records left to iterate.
Warnings
Possible warning codes for sstore_info_read() are as follows:
SS_WARN_INVALID
An ssid is invalid.
Attributes
See attributes(7) for descriptions of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See Also
libsstore(3LIB), sstore_alloc(3SSTORE), sstore_err_action(3SSTORE), sstore_range_alloc(3SSTORE), attributes(7), ssid(7)
