| Administrative operations folder
Set privilege levels for all of the following administrative operations.
| Security administration folder
Set privilege levels for all of the following user management operations accessible on the
Security Manager slider.
| Group operations folder
Set privilege levels for all group item operations.
| Add group item
Set privilege levels to add a new device group.
| Update group item
Modify groups.
| Delete group item
Delete existing groups.
| User operations folder
Set privilege levels for all the following user operations accessible on the
| Add users item
Create new users.
| Update users item
Modify user information.
| Delete users folder
Delete existing users.
| Reset password item
Reset the password for a user who needs to login to
Oracle Communications Report Manager.
| Change password item
Change another user’s password used to login to
| Change inactivity timer item
Change the inactivity timer, which logs off the user if the client is no longer being used.
| Change Password Rule item
Configure the password rules used when creating a new user.
| Edit login banner
Edit the login banner for users logging into
| Password notification
Change the notification interval.
| Device group folder
Assign privilege for all functions pertaining to a device group (see below).
| Add device group item
Set privilege levels to add a new network function containing a device group for either device(s) or a device cluster.
| Delete device group item
Delete a device group.
| Move device group item
Move a device group.
| Rename device group item
Rename a device group.
| Device folder
Assign privilege to all of the following device operations accessible through the
Device Manager and
Configuration Manager sliders.
| Activate device
Activate a new device.
| Add device item
Add a new device.
| Remove device item
Remove an existing device.
| Move device item
Move a device.
| KPI Operation item
Set privilege levels to get device KPIs, register KPIs, deregister KPIs, or update registered KPIs.
| Edit login banner item
Allow users of a group to change the informational banner seen when a user logs into
SDM.
| Change password message interval item
Send alert that prompts user to change their password a certain number of days before their password expires.
| View all audit logs item
View all audit logs.
| View own audit log item
View only personal audit log.
| Change audit log auto purge interval item
Configure the number of days of audit logs to keep.
| Export audit logs item
Export all of an audit log to a file.
| Manual audit log purge item
Manually purge audit logs.
| View health monitor console item
Access health monitor console to detect issues.
| Change configuration archive settings item
Change configuration archive settings.
| Update OS/System account password item
Update the operating system and the system account password.
| Authentication item
Update authentication parameters.
| Server Diagnostics item
Access to server diagnostics.
