To verify that the connector is configured correctly:
Log in to the Oracle Enterprise Manager console with an account that has Super Administrator permissions.
From the Setup menu of the Enterprise Manager console, select Extensibility, then Management Connectors.
The Management Connectors page appears.
Click on the name of the OMU Connector.
The General tab of the Configure Management Connector page appears.
Select and copy the URL specified for the createEvent or updateEvent operation.
Open an internet browser on the system where the Oracle Enterprise Manager server is installed.
In the address window, enter the URL that was copied in step 4 above. Add ?wsdl to the end of the URL. The URL should appear similar to the following example:
http://[Hostname]:8080/services/hpovou/EventService?wsdl
[Hostname] is the actual host name or IP address where the OMU web service is installed.
If the WSDL is loaded, this confirms that the connector is configured correctly for sending event information to OMU.
