To install the software on a UNIX/Solaris machine, perform these steps.
http://www.openssh.org/portable.html#http
If you wish to use one of the other mirror sites, select the closest mirror site.
openssh-3.7.1p1.tar.gz
After the software has been installed, perform the Establishing a Secure Telnet Connection to the EAGLE using UNIX/Solaris OpenSSH procedure.
